[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-79-g3c6da820c
Tue Sep 13 12:38:34 PDT 2022
the project "PostGIS".
       via  3c6da820cff397a6b19dc02cbb391a14d9cf418e (commit)
      from  ad456b38fe05c328e39e65e9481d66b0fa432593 (commit)
revisions in full, below.
commit 3c6da820cff397a6b19dc02cbb391a14d9cf418e
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Sep 13 12:38:31 2022 -0700
    Improve doc for spatial predicates
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index f3530c3f6..06f106c82 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -15,7 +15,7 @@
       <refname>ST_3DIntersects</refname>
       <refpurpose>Tests if two geometries spatially
-      intersect in 3D - only for points, linestrings, polygons, polyhedral surface (area).
+      intersect in 3D - only for points, linestrings, polygons, polyhedral surface (area)
       </refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -77,7 +77,7 @@
     <refnamediv>
     <refname>ST_Contains</refname>
-    <refpurpose>Tests if no points of B lie in the exterior of A, and A and B have at least one interior point in common. </refpurpose>
+    <refpurpose>Tests if every point of B lies in A, and their interiors have a point in common</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -97,22 +97,30 @@
     <refsection>
     <title>Description</title>
-    <para>Returns TRUE if geometry B is completely inside geometry A.
-        A contains B if and only if no points of B lie in the exterior of A, and at least one point of the interior of B lies in the interior of A.
-        </para>
-        <para>A subtlety of the definition is that a geometry does not contain things in its boundary.
-        Thus polygons and lines do <emphasis>not</emphasis> contain lines and points lying in their boundary.
-        For further details see <ulink url="http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html">Subtleties of OGC Covers, Contains, Within</ulink>.
-        (The <xref linkend="ST_Covers" /> predicate provides a more inclusive relationship.)
-        However, a geometry does contain itself.
-        (In contrast, in the <xref linkend="ST_ContainsProperly" />
-        predicate a geometry does <emphasis>not</emphasis> properly contain itself.)</para>
+    <para>Returns TRUE if geometry A contains geometry B.
+    A contains B if and only if all points of B lie inside (i.e. in the interior or boundary of) A
+    (or equivalently, no points of B lie in the exterior of A),
+    and the interiors of A and B have at least one point in common.
+    </para>
-        <para>ST_Contains is the inverse of <xref linkend="ST_Within"/>.
-        So, <code>ST_Contains(A,B) = ST_Within(B,A)</code>.</para>
+    <para>The contains relationship is reflexive: every geometry contains itself.
+    (In contrast, in the <xref linkend="ST_ContainsProperly" />
+    predicate a geometry does <emphasis>not</emphasis> properly contain itself.)
+    The relationship is antisymmetric: if <code>ST_Contains(A,B) = true</code> and <code>ST_Contains(B,A) = true</code>, then
+    the two geometries must be topologically equal (<code>ST_Equals(A,B) = true</code>).
+    </para>
-        <note><para>&index_aware;
-        To avoid index use, use the function <function>_ST_Contains</function>.</para></note>
+    <para>ST_Contains is the converse of <xref linkend="ST_Within"/>.
+    So, <code>ST_Contains(A,B) = ST_Within(B,A)</code>.</para>
+    <note><para>Because the interiors must have a common point, a subtlety of the definition is that
+    polygons and lines do <emphasis>not</emphasis> contain lines and points lying fully in their boundary.
+    For further details see <ulink url="http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html">Subtleties of OGC Covers, Contains, Within</ulink>.
+    The <xref linkend="ST_Covers" /> predicate provides a more inclusive relationship.
+    </para></note>
+    <note><para>&index_aware;
+    To avoid index use, use the function <function>_ST_Contains</function>.</para></note>
     <para>Performed by the GEOS module</para>
     <para>Enhanced: 2.3.0 Enhancement to PIP short-circuit extended to support MultiPoints with few points. Prior versions only supported point in polygon.</para>
@@ -188,7 +196,7 @@
       </tgroup>
     </informaltable>
-    <para>The <function>ST_Contains</function> predicate returns <varname>FALSE</varname> in the following situations:</para>
+    <para><function>ST_Contains</function> returns <varname>FALSE</varname> in the following situations:</para>
     <informaltable>
       <tgroup cols="2">
@@ -261,7 +269,7 @@ ST_Point      | t          | t              | f           | f
     <refnamediv>
     <refname>ST_ContainsProperly</refname>
-    <refpurpose>Tests if B intersects the interior of A but not the boundary or exterior. </refpurpose>
+    <refpurpose>Tests if every point of B lies in the interior of A</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -281,15 +289,16 @@ ST_Point      | t          | t              | f           | f
     <refsection>
-    <para>Returns true if B intersects the interior of A but not the boundary or exterior.</para>
+    <para>Returns <varname>true</varname> if every point of B lies inside A
+    (or equivalently, no point of B lies in the the boundary or exterior of A).</para>
     <para>A does not properly contain itself, but does contain itself.</para>
     <para>Every point of the other geometry is a point of this geometry's interior. The DE-9IM Intersection Matrix for the two geometries matches
    [T**FF*FF*] used in <xref linkend="ST_Relate" /></para>
     <para>
-    An example use case for this predicate is computing the intersections of a set of geometries with a large polygonal geometry. Since intersection is a fairly slow operation, it can be more efficient to use containsProperly to filter out test geometries which lie
-      wholly inside the area.  In these cases the intersection is known a priori to be exactly the original test geometry.
+    A use for this predicate is computing the intersections of a set of geometries with a large polygonal geometry. Since intersection is a fairly slow operation, it can be more efficient to use containsProperly to filter out test geometries which lie
+      fully inside the area.  In these cases the intersection is known a priori to be exactly the original test geometry.
       </para>
@@ -355,7 +364,7 @@ ST_Point      | t          | t              | f           | f
     <refnamediv>
     <refname>ST_CoveredBy</refname>
-    <refpurpose>Tests if no point in A is outside B</refpurpose>
+    <refpurpose>Tests if every point of A lies in B</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -385,11 +394,18 @@ ST_Point      | t          | t              | f           | f
     <refsection>
-      <para>Returns <varname>true</varname> if no point in Geometry/Geography A lies outside
-            Geometry/Geography B.
-            Equivalently, tests if every point of geometry A is inside
-            (i.e. intersects the interior or boundary of) geometry B.
-            </para>
+    <para>Returns <varname>true</varname> if every point in Geometry/Geography A lies inside
+        (i.e. intersects the interior or boundary of)
+        Geometry/Geography B.
+        Equivalently, tests that no point of A lies outside (in the exterior of) B.
+        </para>
+    <para>ST_CoveredBy is the converse of <xref linkend="ST_Covers"/>.
+    So, <code>ST_CoveredBy(A,B) = ST_Covers(B,A)</code>.</para>
+    <para>Generally this function should be used instead of <xref linkend="ST_Within"/>,
+    since it has a simpler definition
+    which does not have the quirk that "boundaries are not within their geometry".</para>
          To avoid index use, use the function <function>_ST_CoveredBy</function>.</para></note>
@@ -437,7 +453,7 @@ FROM (SELECT ST_Buffer(ST_GeomFromText('POINT(1 2)'), 10) As smallc,
     <refnamediv>
     <refname>ST_Covers</refname>
-    <refpurpose>Tests if no point in B is outside A</refpurpose>
+    <refpurpose>Tests if every point of B lies in A</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -466,12 +482,20 @@ FROM (SELECT ST_Buffer(ST_GeomFromText('POINT(1 2)'), 10) As smallc,
     <refsection>
-      <para>Returns <varname>true</varname> if no point in Geometry/Geography B is outside
-      Geometry/Geography A.
-            Equivalently, tests if every point of geometry B is inside
-            (i.e. intersects the interior or boundary of) geometry A.
+      <para>Returns <varname>true</varname> if every point in Geometry/Geography B lies inside
+            Geometry/Geography A.
+            Equivalently, tests that no point of B lies outside (in the exterior of) A.
             </para>
+    <para>ST_Covers is the converse of <xref linkend="ST_CoveredBy"/>.
+    So, <code>ST_Covers(A,B) = ST_CoveredBy(B,A)</code>.</para>
+    <para>Generally this function should be used instead of <xref linkend="ST_Contains"/>,
+    which does not have the quirk that "geometries do not contain their boundary".</para>
          To avoid index use, use the function <function>_ST_Covers</function>.</para></note>
@@ -535,8 +559,7 @@ SELECT ST_Covers(geog_poly, geog_pt) As poly_covers_pt,
   <refnamediv>
     <refname>ST_Crosses</refname>
-    <refpurpose>Tests if two geometries have some, but not all,
-    interior points in common.</refpurpose>
+    <refpurpose>Tests if two geometries have some, but not all, interior points in common</refpurpose>
   </refnamediv>
   <refsynopsisdiv>
@@ -710,8 +733,7 @@ WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
     <refnamediv>
       <refname>ST_Disjoint</refname>
-      <refpurpose>Tests if two geometries are disjoint (they have no point in common).
-      </refpurpose>
+      <refpurpose>Tests if two geometries have no points in common </refpurpose>
     </refnamediv>
     <refsynopsisdiv>
       <funcsynopsis>
@@ -777,7 +799,7 @@ SELECT ST_Disjoint('POINT(0 0)'::geometry, 'LINESTRING ( 0 0, 0 2 )'::geometry);
     <refnamediv>
     <refname>ST_Equals</refname>
-    <refpurpose>Tests if two geometries include the same set of points.</refpurpose>
+    <refpurpose>Tests if two geometries include the same set of points</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -842,9 +864,7 @@ SELECT ST_Equals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
     <refnamediv>
       <refname>ST_Intersects</refname>
-      intersect (they have at least one point in common).
-      </refpurpose>
+      <refpurpose>Tests if two geometries intersect (they have at least one point in common)</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
       <funcsynopsis>
@@ -961,7 +981,7 @@ t
   <refnamediv>
     <refname>ST_LineCrossingDirection</refname>
-    <refpurpose>Returns a number indicating the crossing behavior of two LineStrings.</refpurpose>
+    <refpurpose>Returns a number indicating the crossing behavior of two LineStrings</refpurpose>
   </refnamediv>
   <refsynopsisdiv>
@@ -1127,8 +1147,7 @@ WHERE ST_LineCrossingDirection(s1.geom, s2.geom) > 0;
     <refnamediv>
     <refname>ST_OrderingEquals</refname>
-    <refpurpose>Tests if two geometries represent the same geometry
-    and have points in the same directional order.</refpurpose>
+    <refpurpose>Tests if two geometries represent the same geometry and have points in the same directional order</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -1191,7 +1210,7 @@ SELECT ST_OrderingEquals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
     <refnamediv>
     <refname>ST_Overlaps</refname>
-    <refpurpose>Tests if two geometries intersect and have the same dimension, but are not completely contained by each other.</refpurpose>
+    <refpurpose>Tests if two geometries have the same dimension and intersect, but each has at least one point not in the other</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -1209,10 +1228,10 @@ SELECT ST_OrderingEquals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
     <para>Returns TRUE if geometry A and B "spatially overlap".
     Two geometries overlap if they have the same dimension,
-    each has at least one point not shared by the other
-    (or equivalently neither covers the other),
-    and the intersection of their interiors has the same dimension.
-    The overlaps relationship is symmetrical.
+    their interiors intersect in that dimension.
+    and each has at least one point inside the other
+    (or equivalently, neither one covers the other).
+    The overlaps relationship is symmetric and irreflexive.
     </para>
@@ -1595,7 +1614,7 @@ SELECT pat.name AS relationship, pat.val AS pattern,
     <refname>ST_Touches</refname>
     <refpurpose>Tests if two geometries have at least one point in common,
-    but their interiors do not intersect.</refpurpose>
+    but their interiors do not intersect</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -1750,7 +1769,7 @@ SELECT ST_Touches('LINESTRING(0 0, 1 1, 0 2)'::geometry, 'POINT(0 2)'::geometry)
     <refnamediv>
     <refname>ST_Within</refname>
-    <refpurpose>Tests if no points of A lie in the exterior of B, and A and B have at least one interior point in common.</refpurpose>
+    <refpurpose>Tests if every point of A lies in B, and their interiors have a point in common</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -1770,19 +1789,27 @@ SELECT ST_Touches('LINESTRING(0 0, 1 1, 0 2)'::geometry, 'POINT(0 2)'::geometry)
     <refsection>
-    <para>Returns TRUE if geometry A is completely inside geometry B. For this function to make
+    <para>Returns TRUE if geometry A is within geometry B.
+    A is within B if and only if all points of A lie inside (i.e. in the interior or boundary of) B
+    (or equivalently, no points of A lie in the exterior of B),
+    </para>
+    <para>For this function to make
     sense, the source geometries must both be of the same coordinate projection,
-    having the same SRID.  It is a given that if ST_Within(A,B) is true and ST_Within(B,A) is true, then
-    the two geometries are considered spatially equal.</para>
+    having the same SRID.
+    </para>
+    <para>The within relationship is reflexive: every geometry is within itself.
+    The relationship is antisymmetric: if <code>ST_Within(A,B) = true</code> and <code>ST_Within(B,A) = true</code>, then
+    the two geometries must be topologically equal (<code>ST_Equals(A,B) = true</code>).</para>
-        <para>A subtlety of this definition is that the boundary of a geometry is not within the geometry.
-        This means that lines and points lying in the boundary of a polygon or line are <emphasis>not</emphasis> within the geometry.
-        (The <xref linkend="ST_CoveredBy" /> predicate provides a more inclusive relationship).
-        </para>
+    <para>ST_Within is the converse of <xref linkend="ST_Contains"/>.
+    So, <code>ST_Within(A,B) = ST_Contains(B,A)</code>.</para>
-        <para>ST_Within is the inverse of <xref linkend="ST_Contains"/>.
-        So, <code>ST_Within(A,B) = ST_Contains(B,A)</code>.</para>
+    lines and points lying fully in the boundary of polygons or lines are <emphasis>not</emphasis> within the geometry.
+    The <xref linkend="ST_CoveredBy" /> predicate provides a more inclusive relationship.
+    </para></note>
         To avoid index use, use the function <function>_ST_Within</function>.</para></note>
@@ -2171,7 +2198,7 @@ SELECT b.tower_id, b.geom
     <refnamediv>
     <refname>ST_PointInsideCircle</refname>
-    <refpurpose>Tests if a point geometry is inside a circle defined by a center and radius.</refpurpose>
+    <refpurpose>Tests if a point geometry is inside a circle defined by a center and radius</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
Summary of changes:
 doc/reference_relationship.xml | 149 ++++++++++++++++++++++++-----------------
 1 file changed, 88 insertions(+), 61 deletions(-)
hooks/post-receive
