[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-80-g1aa5a723c
Tue Sep 13 13:52:19 PDT 2022
the project "PostGIS".
       via  1aa5a723cf03653c19df9a3c34eb94e9079b12d0 (commit)
      from  3c6da820cff397a6b19dc02cbb391a14d9cf418e (commit)
revisions in full, below.
commit 1aa5a723cf03653c19df9a3c34eb94e9079b12d0
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Sep 13 13:52:15 2022 -0700
    Improve doc for MinBoundingCircle and LongestLine
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index c2c04e0d9..a0fdf7a92 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -1254,7 +1254,7 @@ CAST('SPHEROID["GRS_1980",6378137,298.257222101]' As spheroid) As sph_m)  as foo
 		</para>
         <para>
         If g1 and g2 are the same geometry, returns the line between the two vertices farthest apart in the geometry.
-        This is a diameter of the circle computed by <xref linkend="ST_MinimumBoundingCircle"/>
+        The endpoints of the line lie on the circle computed by <xref linkend="ST_MinimumBoundingCircle"/>.
         </para>
 		<para>Availability: 1.5.0</para>
@@ -1306,7 +1306,7 @@ LINESTRING(20 10,105.3073372946034 186.95518130045156)
             </imageobject>
             <caption><para>Longest line across a single geometry.
             The length of the line is equal to the Maximum Distance.
-            The line is a diameter of the Minimum Bounding Circle.</para></caption>
+            The endpoints of the line lie on the Minimum Bounding Circle.</para></caption>
         </mediaobject>
         </informalfigure>
 <programlisting>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 00fb02e83..cff29187c 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1454,8 +1454,10 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
             The approximation can be improved by increasing the number of segments.
             For applications where an approximation is not suitable <xref linkend="ST_MinimumBoundingRadius" /> may be used.</para></note>
-            <para>This function is not an aggregate. It can be used
-            with <xref linkend="ST_Collect" /> to get the minimum bounding circle of a set of geometries.</para>
+        <para>Use with <xref linkend="ST_Collect" /> to get the minimum bounding circle of a set of geometries.</para>
+        <para>To compute two points lying on the mimimum circle (the "maximum diameter") use <xref linkend="ST_LongestLine" />.
+        </para>
         <para>The ratio of the area of a polygon divided by the area of its Minimum Bounding Circle
         is referred to as the <emphasis>Reock compactness score</emphasis>.</para>
@@ -1463,10 +1465,6 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
         <para>Availability: 1.4.0</para>
       </refsection>
-      <refsection>
-        <title>See Also</title>
-        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingRadius" /></para>
-      </refsection>
       <refsection>
         <title>Examples</title>
@@ -1499,7 +1497,7 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
       </refsection>
       <refsection>
-        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingRadius" /> </para>
+        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingRadius" />, <xref linkend="ST_LongestLine" /> </para>
       </refsection>
     </refentry>
@@ -1528,15 +1526,14 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
             <listitem><para> <varname>radius</varname> - radius of the circle </para></listitem>
         </itemizedlist>
-        <para>Use in conjunction with <xref linkend="ST_Collect"/> to get the minimum bounding circle of a set of geometries.</para>
+        <para>Use with <xref linkend="ST_Collect"/> to get the minimum bounding circle of a set of geometries.</para>
+        </para>
         <para>Availability - 2.3.0</para>
     </refsection>
-      <refsection>
-        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingCircle" /></para>
-      </refsection>
       <refsection>
 <programlisting>SELECT ST_AsText(center), radius FROM ST_MinimumBoundingRadius('POLYGON((26426 65078,26531 65242,26075 65136,26096 65427,26426 65078))');
@@ -1547,6 +1544,11 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
 </programlisting>
       </refsection>
+      <refsection>
+        <title>See Also</title>
+        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingCircle" />, <xref linkend="ST_LongestLine" /></para>
+      </refsection>
     </refentry>
     <refentry id="ST_OrientedEnvelope">
@@ -1579,14 +1581,6 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
             </para>
         </refsection>
-        <refsection>
-            <para>
-                <xref linkend="ST_Envelope" />
-                <xref linkend="ST_MinimumBoundingCircle" />
-            </para>
-        </refsection>
         <refsection>
             <programlisting>
@@ -1617,6 +1611,14 @@ POLYGON((19.9999999999997 79.9999999999999,33.0769230769229 60.3846153846152,138
 </programlisting>
         </refsection>
+        <refsection>
+            <para>
+                <xref linkend="ST_Envelope" />
+                <xref linkend="ST_MinimumBoundingCircle" />
+            </para>
+        </refsection>
     </refentry>
     <refentry id="ST_OffsetCurve">
Summary of changes:
 doc/reference_measure.xml    |  4 ++--
 doc/reference_processing.xml | 44 +++++++++++++++++++++++---------------------
 2 files changed, 25 insertions(+), 23 deletions(-)
hooks/post-receive
