[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-89-g63b1fb14a
Wed Sep 14 05:07:33 PDT 2022
the project "PostGIS".
       via  63b1fb14a79f4d09776537838b5159c7750d3b57 (commit)
      from  d72f690f5eaa34089c10ace378712700ce9012bf (commit)
revisions in full, below.
commit 63b1fb14a79f4d09776537838b5159c7750d3b57
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 14 14:06:40 2022 +0200
    Reduce processes creating sql/ dir for address_standardizer
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index ea980d9af..00c76155c 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -59,11 +59,12 @@ SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = sql/ usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
 REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2
+sql:
+	mkdir -p $@
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
-sql/%.sql: %.sql.in
-	mkdir -p sql
+sql/%.sql: %.sql.in | sql
 	$(SQLPP) -I at buiddir@/../libpgcommon $< | grep -v '^#' | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
@@ -72,18 +73,15 @@ sql/%.sql: %.sql.in
 		| $(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
-sql/address_standardizer_pre.sql: $(EXTENSION_SCRIPTS)
-	mkdir -p sql
+sql/address_standardizer_pre.sql: $(EXTENSION_SCRIPTS) | sql
 	cat $^ > $@
-sql/address_standardizer--$(EXTVERSION).sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
-	mkdir -p sql
+sql/address_standardizer--$(EXTVERSION).sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl | sql
 	cat $< \
 		| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/address_standardizer_pre.sql \
-sql/address_standardizer.sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
-	mkdir -p sql
+sql/address_standardizer.sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl | sql
 	cat $< \
@@ -91,39 +89,32 @@ sql/address_standardizer.sql: sql/address_standardizer_pre.sql ../../utils/creat
 EXTENSION_UPGRADE_SCRIPTS = sql/address_standardizer_functions.sql
 # upgrade logic for us data extension (to go to original round-robin yoyo cludge for dev upgrading)
-sql/$(EXTENSION)--1.0--$(EXTVERSION).sql: sql/address_standardizer_functions.sql
-	mkdir -p sql
+sql/$(EXTENSION)--1.0--$(EXTVERSION).sql: sql/address_standardizer_functions.sql | sql
 	cat $^ > $@
-sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/address_standardizer_functions.sql
-	mkdir -p sql
+sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/address_standardizer_functions.sql | sql
 	cat $^ > $@
 # build us data extension
-sql/$(EXTENSION)_data_us--$(EXTVERSION).sql: us_lex.sql us_gaz.sql us_rules.sql sql_bits/address_standardizer_data_us_mark_editable_objects.sql.in
-	mkdir -p sql
+sql/$(EXTENSION)_data_us--$(EXTVERSION).sql: us_lex.sql us_gaz.sql us_rules.sql sql_bits/address_standardizer_data_us_mark_editable_objects.sql.in | sql
 	cat $^ > $@
-sql/$(EXTENSION)_data_us.sql: us_lex.sql us_gaz.sql us_rules.sql sql_bits/address_standardizer_data_us_mark_editable_objects.sql.in
-	mkdir -p sql
+sql/$(EXTENSION)_data_us.sql: us_lex.sql us_gaz.sql us_rules.sql sql_bits/address_standardizer_data_us_mark_editable_objects.sql.in | sql
 	cat $^ > $@
 # upgrade logic for us data extension (to go to next cludge for dev upgrading)
-sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql
-	mkdir -p sql
+sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql | sql
 	cat $^ > $@
-sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql
-	mkdir -p sql
+sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql | sql
 	cat $^ > $@
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
 	cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
-sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql
-	mkdir -p sql
+sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql | sql
 	cat $^ > $@
 include @srcdir@/../upgrade-paths-rules.mk
Summary of changes:
 extensions/address_standardizer/Makefile.in | 35 +++++++++++------------------
 1 file changed, 13 insertions(+), 22 deletions(-)
hooks/post-receive
