[postgis-tickets] [PostGIS] #5240: ST_DumpPoints crash with multipolygon that includes an empty polygon
PostGIS trac at osgeo.org
Thu Sep 15 14:13:47 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.2.4
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 SELECT ST_DumpPoints(foo1.the_geom)  As result
         FROM (
                         SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1,
 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom ) As foo1;
 This I tested on 3.2.4dev, but haven't tested others to see how far back
 is the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5240>
