[postgis-tickets] [PostGIS] #5240: ST_DumpPoints and ST_DumpSegments crash with multipolygon that includes an empty polygon (was: ST_DumpPoints crash with multipolygon that includes an empty polygon)
PostGIS trac at osgeo.org
Thu Sep 15 21:22:41 PDT 2022
empty polygon
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.8
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Changes (by robe):
 * summary:  ST_DumpPoints crash with multipolygon that includes an empty
     polygon =>
 * milestone:  PostGIS 3.2.4 => PostGIS 3.0.8
Old description:
> SELECT ST_DumpPoints(foo1.the_geom)  As result
>         FROM (
>                         SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1,
> 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom ) As foo1;
> This I tested on 3.2.4dev, but haven't tested others to see how far back
> is the issue.
New description:
         FROM (
 is the issue.
Comment:
 SELECT ST_DumpSegments(foo1.the_geom)  As result
                                                         FROM (
                 (SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2
 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom ) ) As foo1 LIMIT 10;
 I'm going to assume these issues have been here for a while.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5240#comment:1>
