[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-98-g15b471af5
Fri Sep 16 10:09:15 PDT 2022
the project "PostGIS".
       via  15b471af52705e753ad8461dcbe6f0192f7d4e7f (commit)
       via  95f1df75c3951e7c4c7366561b6ee22ded452c4c (commit)
      from  09d4454f7b2b973c18337e0bb15a737f40db522f (commit)
revisions in full, below.
commit 15b471af52705e753ad8461dcbe6f0192f7d4e7f
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 16 13:08:47 2022 -0400
    Put in MULTIPOLYGON(polygon, empty) monster to catch more crashers
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 4907d2be7..e49ce0c38 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -8,9 +8,9 @@
 			using a garden variety of geometries.  Its intent is to flag major crashes.
 	<xsl:output method="text" />
-	<xsl:variable name='testversion'>3.3.0</xsl:variable>
+	<xsl:variable name='testversion'>3.4.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_DumpPoints ST_DumpSegments ST_SnapToGrid</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -246,6 +246,10 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 		(SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom)
 		</pgis:gset>
+		<pgis:gset ID='MULTIPOLYGON with Empty' GeometryType='MULTIPOLYGON'>
+		(SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom )
+		</pgis:gset>
 		<pgis:gset ID="Empty Polygon" GeometryType="POLYGON" createtable="false">
 		(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)
 		</pgis:gset>
commit 95f1df75c3951e7c4c7366561b6ee22ded452c4c
Date:   Fri Sep 16 13:07:47 2022 -0400
    Take out raster build in gitlab to prevent PACKAGE_URL conflict
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index d58d67b0f..16a010e5f 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -23,7 +23,7 @@
     - echo "SRCDIR is ${SRCDIR}"
     - mkdir /tmp/build && cd /tmp/build
     - echo "Build dir is ${PWD}"
-    - ${SRCDIR}/configure CFLAGS="-Wall -fno-omit-frame-pointer -Werror"
+    - ${SRCDIR}/configure --without-raster CFLAGS="-Wall -fno-omit-frame-pointer -Werror"
     - make
     - RUNTESTFLAGS=-v make check
     - RUNTESTFLAGS="-v --dumprestore" make check-regress
Summary of changes:
 .gitlab-ci.yml                     | 2 +-
 doc/xsl/postgis_gardentest.sql.xsl | 8 ++++++--
 2 files changed, 7 insertions(+), 3 deletions(-)
hooks/post-receive
