[postgis-tickets] [PostGIS] #5052: Add support for specifying target version in postgis_extensions_upgrade()
PostGIS trac at osgeo.org
Fri Sep 16 10:17:22 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by robe):
 * milestone:  PostGIS Fund Me => PostGIS 3.4.0
Comment:
 Might be worthwhile as part of this using a procedure instead.
 So we introduce a CREATE  PROCEDURE
 postgis_extensions_upgrade(target_version).
 That way we can keep the existing, but have it do CALL.  So no breaking
 changes.
 Since the CREATE PROCEDURE has a different signature from existing, it can
 coexist.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5052#comment:3>
