[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-111-gb3fcb2d8e
Sat Sep 17 12:15:02 PDT 2022
the project "PostGIS".
       via  b3fcb2d8e0ae0a0e9f25393a035f9cb7367c704a (commit)
       via  dba51176c5d1a7576f0df71c7cd4154281af79ee (commit)
      from  92b3ff24e095872e9fcd3d2bef2a8a622c7a1c15 (commit)
revisions in full, below.
commit b3fcb2d8e0ae0a0e9f25393a035f9cb7367c704a
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Sep 17 16:24:40 2022 +0200
    [gitlab-ci] Use debian bookworm and PostgreSQL 14
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index 16a010e5f..690762ee9 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -4,7 +4,7 @@
   before_script:
     - apt-get update -qq && apt-get install -y
         bison flex
-        postgresql-13 postgresql-server-dev-13
+        postgresql-14 postgresql-server-dev-14
         build-essential autoconf libtool libcunit1-dev
         xsltproc docbook-xsl docbook-mathml dblatex
         libproj-dev libgdal-dev libgeos-dev libjson-c-dev
@@ -34,9 +34,9 @@
     - ${SRCDIR}/utils/check_distclean.sh
 test:
-  image: debian:bullseye
+  image: debian:bookworm
   <<: *build_definition
 test32:
-  image: i386/debian:bullseye
+  image: i386/debian:bookworm
commit dba51176c5d1a7576f0df71c7cd4154281af79ee
Date:   Fri Sep 16 23:33:25 2022 +0200
    Fix partly outside array bounds gcc warning
    Closes #5233
diff --git a/libpgcommon/gserialized_gist.h b/libpgcommon/gserialized_gist.h
index b3e0ca75a..8edade557 100644
--- a/libpgcommon/gserialized_gist.h
+++ b/libpgcommon/gserialized_gist.h
@@ -56,16 +56,12 @@ bool gidx_is_unknown(const GIDX *a);
 /* Generate human readable form for GIDX. */
 char *gidx_to_string(GIDX *a);
-/* typedef to correct array-bounds checking for casts to GIDX - do not
-   use this ANYWHERE except in the casts below */
-typedef float _gidx_float_array[sizeof(float) * 2 * 4];
 /* Returns number of dimensions for this GIDX */
 #define GIDX_NDIMS(gidx) ((VARSIZE((gidx)) - VARHDRSZ) / (2 * sizeof(float)))
 /* Minimum accessor. */
-#define GIDX_GET_MIN(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2 * (dimension)]
+#define GIDX_GET_MIN(gidx, dimension) *( (gidx)->c + 2 * (dimension) )
 /* Maximum accessor. */
-#define GIDX_GET_MAX(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2 * (dimension) + 1]
+#define GIDX_GET_MAX(gidx, dimension) *( (gidx)->c + 2 * (dimension) + 1 )
 /* Minimum setter. */
 #define GIDX_SET_MIN(gidx, dimension, value) ((gidx)->c[2 * (dimension)] = (value))
 /* Maximum setter. */
Summary of changes:
 .gitlab-ci.yml                 | 6 +++---
 libpgcommon/gserialized_gist.h | 8 ++------
 2 files changed, 5 insertions(+), 9 deletions(-)
hooks/post-receive
