[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-112-g1c0838e78
Sat Sep 17 12:54:00 PDT 2022
the project "PostGIS".
       via  1c0838e7899de623ef842fd2dd5b2cb29b84076b (commit)
      from  b3fcb2d8e0ae0a0e9f25393a035f9cb7367c704a (commit)
revisions in full, below.
commit 1c0838e7899de623ef842fd2dd5b2cb29b84076b
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Sep 17 21:51:28 2022 +0200
    Ask pg_extension_update_paths if an upgrade path is available
    Rather than making assumption about files on disk
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 427234d8b..92012a988 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -176,9 +176,14 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
       test_label="${test_label} ($to_version)"
     fi
     compatible_upgrade "${test_label}" ${from_version} ${to_version} || continue
-    UPGRADE_FILE="${EXT}--${from_version}--${to_version}.sql"
-    if ! test -e ${UPGRADE_FILE}; then
-      echo "SKIP: ${test_label} ($UPGRADE_FILE is missing)"
+    path=$( psql -XAtc "
+        SELECT path
+        FROM pg_catalog.pg_extension_update_paths('${EXT}')
+        WHERE source = '${from_version}'
+        AND target = '${to_version}'
+    if test -z "${path}"; then
+      echo "SKIP: ${test_label} (no upgrade path from ${from_version} to ${to_version} known by postgresql)"
       continue
     fi
     echo "Testing ${test_label}"
@@ -199,9 +204,14 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
     fi
     compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
-    UPGRADE_FILE="${EXT}--unpackaged--${to_version}.sql"
+        SELECT path
+        WHERE source = 'unpackaged'
+      echo "SKIP: ${test_label} (no upgrade path from unpackaged to ${to_version} known by postgresql)"
       continue
     fi
Summary of changes:
 utils/check_all_upgrades.sh | 22 ++++++++++++++++------
 1 file changed, 16 insertions(+), 6 deletions(-)
hooks/post-receive
