[postgis-tickets] [PostGIS] #5245: Regression failure with relate_bnr
PostGIS trac at osgeo.org
Mon Sep 19 18:46:50 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  master
 Keywords:           |
 I'm assuming this is a GEOS change?
 I'm seeing a failure on winnie
 PostgreSQL 14.5, compiled by Visual C++ build 1914, 64-bit
   Postgis 3.4.0dev - (3.3.0rc2-115-gcb7577657) - 2022-09-19 04:41:50
   scripts 3.4.0dev 3.3.0rc2-115-gcb7577657
   raster scripts 3.4.0dev 3.3.0rc2-115-gcb7577657
   GEOS: 3.12.0dev-CAPI-1.18.0
   PROJ: 7.2.1
   SFCGAL: 1.4.1
   GDAL: GDAL 3.4.3, released 2022/04/22
  ./regress/core/relate_bnr .. failed (diff expected obtained:
 /projects/postgis/tmp/3.4.0dev_pg14_geos3.12_gdal3.4.3w64/test_99_diff)
 --- ./regress/core/relate_bnr_expected  2022-08-27 01:03:00.888083800
 -0400
 +++ /projects/postgis/tmp/3.4.0dev_pg14_geos3.12_gdal3.4.3w64/test_99_out
 2022-09-19 01:01:32.833635900 -0400
 @@ -28,7 +28,7 @@
  28|10FF0FFF2|10FF0FFF2|1FFFFFFF2|10FF0FFF2
  29|FF1FF0102|FF1FF0102|FF1FF0102|FF1FF0102
  30|FF1FF0102|FF1FF0102|FF1FFF1F2|FF1FF0102
 -31|FF1FF01F2|FF1FF01F2|FF1FF01F2|FF1FF01F2
 +31|FF1FF01F2|FF1FF0102|FF1FF0102|FF1FF01F2
  32|FF1FF01F2|FF1FF0102|FF1FFF1F2|FF1FF01F2
  33|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
  34|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 debbie seems okay, but I realized ack she's not running against GEOS main
 for PostGIS master
 GEOS: 3.11.1dev-CAPI-1.17.1
 Although GH pg15-geos311-gdal35-proj90 is failing with same error
 PostgreSQL 15beta4 on x86_64-pc-linux-gnu, compiled by gcc (Debian
 10.2.1-6) 10.2.1 20210110, 64-bit
   Postgis 3.4.0dev - (cb75776) - 2022-09-19 04:06:13
   scripts 3.4.0dev cb75776
   raster scripts 3.4.0dev cb75776
   PROJ: 9.0.1
   SFCGAL: 1.4.1
   GDAL: GDAL 3.5.2, released 2022/09/02
 /tmp/pgis_reg/test_99_diff)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5245>
