[postgis-tickets] [PostGIS] #5245: Regression failure with relate_bnr
PostGIS trac at osgeo.org
Mon Sep 19 19:08:29 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 okay debbie is now failing too:
 21:42:38 PostgreSQL 15beta4 on x86_64-pc-linux-gnu, compiled by gcc
 (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
 21:42:38   Postgis 3.4.0dev - (3.3.0rc2-117-gf24ef8556) - 2022-09-20
 01:38:32
 21:42:38   scripts 3.4.0dev 3.3.0rc2-117-gf24ef8556
 21:42:38   raster scripts 3.4.0dev 3.3.0rc2-117-gf24ef8556
 21:42:38   GEOS: 3.11.1dev-CAPI-1.17.1
 21:42:38   PROJ: 7.2.1
 21:42:38   SFCGAL: 1.3.8
 21:42:38   GDAL: GDAL 3.4.3, released 2022/04/22
 21:43:18  ./regress/core/relate_bnr .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg15w64/test_99_diff)
 21:43:18
 21:43:18 --- ./regress/core/relate_bnr_expected 2022-08-22
 20:53:14.447687571 +0000
 21:43:18 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg15w64/test_99_out
 2022-09-20 01:43:18.602998038 +0000
 21:43:18 @@ -28,7 +28,7 @@
 21:43:18  28|10FF0FFF2|10FF0FFF2|1FFFFFFF2|10FF0FFF2
 21:43:18  29|FF1FF0102|FF1FF0102|FF1FF0102|FF1FF0102
 21:43:18  30|FF1FF0102|FF1FF0102|FF1FFF1F2|FF1FF0102
 21:43:18 -31|FF1FF01F2|FF1FF01F2|FF1FF01F2|FF1FF01F2
 21:43:18 +31|FF1FF01F2|FF1FF0102|FF1FF0102|FF1FF01F2
 21:43:18  32|FF1FF01F2|FF1FF0102|FF1FFF1F2|FF1FF01F2
 21:43:18  33|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 21:43:18  34|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 21:43:18
 so maybe her last run was using a slightly older GEOS.
 Not all the GH bots running GEOS 3.7-3.9 are not failing so assuming it
 must be a GEOS change in main, and 3.11 branches
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5245#comment:1>
