[postgis-tickets] [PostGIS] #5369: GetTopoGeomElements documentation does not mention the return is about primitives
PostGIS trac at osgeo.org
Thu Apr 13 05:35:14 PDT 2023
primitives
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.0.9
Component:  topology  |    Version:  3.0.x
 Keywords:            |
 For hierarchical TopoGeometry objects, GetTopoGeomElements, I believe, is
 always returning primitive components, rather than the actual child-layer
 elements.
 This should be clearly documented (after proper verification).
 We might at some point add a parameter to specify which elements we want
 (primitive or lower layer)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5369>
