[postgis-tickets] [PostGIS] #5368: cirrus CI 12.3 failing on flatgeobuf compile error: unknown warning option '-Wno-compound-token-split-by-macro'
PostGIS trac at osgeo.org
Fri Apr 14 17:23:41 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:  fixed      |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"5da0ec6e80a4a1e414433e79289482c35ef32474/git" 5da0ec6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="5da0ec6e80a4a1e414433e79289482c35ef32474"
 Remove cirrus freebsd-12-3 which is failing
 bessie tests freebsd 12-3, so we are covered there anyway
 Closes #5368
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5368#comment:3>
