[postgis-tickets] [PostGIS] #5372: macOs CI: cannot build with topology
PostGIS trac at osgeo.org
Tue Apr 18 05:25:28 PDT 2023
 Reporter:  lbartoletti  |      Owner:  strk
     Type:  defect       |     Status:  new
 Priority:  low          |  Milestone:  PostGIS 3.3.3
Component:  topology     |    Version:  3.3.x
 Keywords:  macos, ci    |
 As mentioned on [https://github.com/postgis/postgis/pull/729] there is an
 error when topology is enabled:
 #/usr/bin/perl -0777 -ne 's/^(CREATE|ALTER)
 (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;'
 topology.sql > topology_upgrade.sql.in
 echo "BEGIN;" > topology_upgrade.sql
 cat topology_before_upgrade.sql topology_upgrade.sql.in
 topology_after_upgrade.sql > topology_upgrade.sql
 echo "COMMIT;" >> topology_upgrade.sql
 9 warnings generated.
 clang -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Werror=unguarded-availability-new -Wendif-labels
 -Wmissing-format-attribute -Wcast-function-type -Wformat-security -fno-
 strict-aliasing -fwrapv -Wno-unused-command-line-argument -Wno-compound-
 token-split-by-macro -O2  -bundle -multiply_defined suppress -o
 postgis_topology-3.so postgis_topology.o -L/opt/homebrew/lib/postgresql at 14
 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.sdk
 -L/opt/homebrew/opt/openssl at 1.1/lib -L/opt/homebrew/opt/readline/lib
 -L/opt/homebrew/Cellar/lz4/1.9.4/lib  -Wl,-dead_strip_dylibs
 ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
 -L/opt/homebrew/Cellar/geos/3.11.2/lib -lgeos_c
 -L/opt/homebrew/Cellar/proj/9.2.0/lib -lproj
 -L/opt/homebrew/Cellar/json-c/0.16/lib -ljson-c
 -L/opt/homebrew/Cellar/protobuf-c/1.4.1_1/lib -lprotobuf-c
 -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib -lxml2 -lz
 -lpthread -licucore -lm -L/opt/homebrew/Cellar/sfcgal/1.4.1_4/lib -lSFCGAL
 -lm -L/opt/homebrew/Cellar/sfcgal/1.4.1_4/lib -lSFCGAL -bundle_loader
 /usr/local/bin/postgres
 ld: file not found: /usr/local/bin/postgres
 clang: error: linker command failed with exit code 1 (use -v to see
 invocation)
 make[1]: *** [postgis_topology-3.so] Error 1
 make: *** [all] Error 1
 Stopping `postgresql at 14`... (might take a while)
 ==> Successfully stopped `postgresql at 14` (label:
 homebrew.mxcl.postgresql at 14)
 But, it seems to be only for the CI, since postgis comes with topology
 enabled on homebrew [https://github.com/Homebrew/homebrew-
 core/blob/d608de039eb7d30b92c52f8c7f6e030969f476d3/Formula/postgis.rb]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5372>
