[postgis-tickets] [PostGIS] #5372: macOs CI: cannot build with topology
PostGIS trac at osgeo.org
Tue Apr 18 06:36:42 PDT 2023
  Reporter:  lbartoletti  |      Owner:  strk
      Type:  defect       |     Status:  new
  Priority:  low          |  Milestone:  PostGIS 3.3.3
 Component:  topology     |    Version:  3.3.x
Resolution:               |   Keywords:  macos, ci
Comment (by strk):
 The clang line is written by PGXS, could you attach the topology/Makefile
 and the PGXS file referenced in it ? {{{ grep ^PGXS topolgy/Makefile }}}
 Is 3.3 the oldest branch affected ? Could you test older stable branches
 too ?
 Is there any way to directly access the problematic system via ssh ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5372#comment:1>
