[postgis-tickets] [PostGIS] #5375: topology tests failing on debbie PG16
PostGIS trac at osgeo.org
Thu Apr 20 18:09:55 PDT 2023
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.3.3
Component:  topology  |    Version:  3.3.x
 Keywords:            |
 I think this is an issue with PG16 since winnie tests latest GEOS too and
 is doing fine.
 At a glance I think this is just a sorting difference. Seems to have
 started April 20th.  April 18th (the last before this) did not have this
 issue.  Have no clue which commit in PostgreSQL caused this, but assume it
 doesn't matter since it's just a sorting issue
 18:12:34  topology/test/regress/st_newedgeheal .. ok in 897 ms
 18:12:35  topology/test/regress/st_newedgessplit .. ok in 351 ms
 18:12:35  topology/test/regress/st_remedgemodface .. failed (diff expected
 obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_209_diff)
 18:12:37
 18:12:37 --- ./topology/test/regress/st_remedgemodface_expected 2023-01-30
 15:52:20.218179908 +0000
 18:12:37 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_209_out
 2023-04-20 22:12:37.104022704 +0000
 18:12:37 @@ -4,175 +4,175 @@
 18:12:37  ERROR:  SQL/MM Spatial exception - non-existent edge 0
 18:12:37  ERROR:  SQL/MM Spatial exception - non-existent edge 143
 18:12:37  RM(25)|1
 18:12:37 -RM(25)/nodes|+|21|1
 18:12:37  RM(25)/nodes|-|21|
 18:12:37 -RM(25)/nodes|+|22|1
 18:12:37 +RM(25)/nodes|+|21|1
 18:12:37  RM(25)/nodes|-|22|
 18:12:37 +RM(25)/nodes|+|22|1
 18:12:37  RM(25)/edges|-|25|-25|25|1|1
 18:12:37  RM(4)|0
 18:12:37 -RM(4)/nodes|+|5|0
 18:12:37  RM(4)/nodes|-|5|
 18:12:37 +RM(4)/nodes|+|5|0
 18:12:37  RM(4)/edges|-|4|-5|4|0|0
 18:12:37 -RM(4)/edges|+|5|-5|5|0|0
 18:12:37  RM(4)/edges|-|5|-4|5|0|0
 18:12:37 +RM(4)/edges|+|5|-5|5|0|0
 18:12:37  RM(26)|1
 18:12:37 -RM(26)/nodes|+|20|1
 18:12:37  RM(26)/nodes|-|20|
 18:12:37 +RM(26)/nodes|+|20|1
 18:12:37  RM(26)/edges|-|26|26|-26|9|1
 18:12:37  RM(26)/faces|-|9|SRID=4326;POLYGON((4 31,4 34,7 34,7 31,4 31))
 18:12:37  RM(9)|6
 18:12:37 -RM(9)/edges|+|6|7|-21|0|6
 18:12:37  RM(9)/edges|-|6|7|-21|0|3
 18:12:37 +RM(9)/edges|+|6|7|-21|0|6
 18:12:37  RM(9)/edges|-|9|19|-22|3|6
 18:12:37 -RM(9)/edges|+|19|-6|-10|6|4
 18:12:37  RM(9)/edges|-|19|-6|-10|3|4
 18:12:37 -RM(9)/edges|+|20|19|13|6|7
 18:12:37 +RM(9)/edges|+|19|-6|-10|6|4
 18:12:37  RM(9)/edges|-|20|-9|13|6|7
 18:12:37 -RM(9)/edges|+|21|6|-22|0|6
 18:12:37 +RM(9)/edges|+|20|19|13|6|7
 18:12:37  RM(9)/edges|-|21|6|9|0|3
 18:12:37 +RM(9)/edges|+|21|6|-22|0|6
 18:12:37  RM(9)/faces|-|3|SRID=4326;POLYGON((9 14,9 22,21 22,21 14,9 14))
 18:12:37 -RM(9)/faces|+|6|SRID=4326;POLYGON((9 6,9 22,21 22,21 6,9 6))
 18:12:37  RM(9)/faces|-|6|SRID=4326;POLYGON((9 6,9 14,21 14,21 6,9 6))
 18:12:37 +RM(9)/faces|+|6|SRID=4326;POLYGON((9 6,9 22,21 22,21 6,9 6))
 18:12:37  RM(19)|4
 18:12:37 -RM(19)/edges|+|6|7|-21|0|4
 18:12:37  RM(19)/edges|-|6|7|-21|0|6
 18:12:37 -RM(19)/edges|+|7|8|-6|0|4
 18:12:37 +RM(19)/edges|+|6|7|-21|0|4
 18:12:37  RM(19)/edges|-|7|8|-19|0|4
 18:12:37 -RM(19)/edges|+|12|20|22|4|0
 18:12:37 +RM(19)/edges|+|7|8|-6|0|4
 18:12:37  RM(19)/edges|-|12|20|22|6|0
 18:12:37 +RM(19)/edges|+|12|20|22|4|0
 18:12:37  RM(19)/edges|-|19|-6|-10|6|4
 18:12:37 -RM(19)/edges|+|20|-10|13|4|7
 18:12:37  RM(19)/edges|-|20|19|13|6|7
 18:12:37 -RM(19)/edges|+|21|6|-22|0|4
 18:12:37 +RM(19)/edges|+|20|-10|13|4|7
 18:12:37  RM(19)/edges|-|21|6|-22|0|6
 18:12:37 -RM(19)/edges|+|22|21|12|0|4
 18:12:37 +RM(19)/edges|+|21|6|-22|0|4
 18:12:37  RM(19)/edges|-|22|21|12|0|6
 18:12:37 -RM(19)/faces|+|4|SRID=4326;POLYGON((9 6,9 22,35 22,35 6,9 6))
 18:12:37 +RM(19)/edges|+|22|21|12|0|4
 18:12:37  RM(19)/faces|-|4|SRID=4326;POLYGON((21 14,21 22,35 22,35 14,21
 14))
 18:12:37 +RM(19)/faces|+|4|SRID=4326;POLYGON((9 6,9 22,35 22,35 6,9 6))
 18:12:37  RM(19)/faces|-|6|SRID=4326;POLYGON((9 6,9 22,21 22,21 6,9 6))
 18:12:37  RM(10)|4
 18:12:37  RM(10)/edges|-|10|-20|17|7|4
 18:12:37 -RM(10)/edges|+|13|18|-12|4|0
 18:12:37  RM(10)/edges|-|13|18|-12|7|0
 18:12:37 -RM(10)/edges|+|18|17|14|4|8
 18:12:37 +RM(10)/edges|+|13|18|-12|4|0
 18:12:37  RM(10)/edges|-|18|10|14|7|8
 18:12:37 -RM(10)/edges|+|20|-20|13|4|4
 18:12:37 +RM(10)/edges|+|18|17|14|4|8
 18:12:37  RM(10)/edges|-|20|-10|13|4|7
 18:12:37 +RM(10)/edges|+|20|-20|13|4|4
 18:12:37  RM(10)/faces|-|7|SRID=4326;POLYGON((21 6,21 14,35 14,35 6,21 6))
 18:12:37  RM(20)|4
 18:12:37 -RM(20)/nodes|+|14|4
 18:12:37  RM(20)/nodes|-|14|
 18:12:37 -RM(20)/edges|+|12|13|22|4|0
 18:12:37 +RM(20)/nodes|+|14|4
 18:12:37  RM(20)/edges|-|12|20|22|4|0
 18:12:37 +RM(20)/edges|+|12|13|22|4|0
 18:12:37  RM(20)/edges|-|20|-20|13|4|4
 18:12:37  RM(15)|0
 18:12:37 -RM(15)/edges|+|8|-8|-17|0|0
 18:12:37  RM(15)/edges|-|8|-15|-17|0|5
 18:12:37 -RM(15)/edges|+|11|-16|-18|0|8
 18:12:37 +RM(15)/edges|+|8|-8|-17|0|0
 18:12:37  RM(15)/edges|-|11|15|-18|5|8
 18:12:37 +RM(15)/edges|+|11|-16|-18|0|8
 18:12:37  RM(15)/edges|-|15|-8|-16|5|0
 18:12:37 -RM(15)/edges|+|17|-7|11|4|0
 18:12:37  RM(15)/edges|-|17|-7|11|4|5
 18:12:37 +RM(15)/edges|+|17|-7|11|4|0
 18:12:37  RM(15)/faces|-|5|SRID=4326;POLYGON((35 14,35 22,47 22,47 14,35
 14))
 18:12:37  RM(2)|0
 18:12:37 -RM(2)/nodes|+|4|0
 18:12:37  RM(2)/nodes|-|4|2
 18:12:37 +RM(2)/nodes|+|4|0
 18:12:37  RM(2)/edges|-|2|3|-2|2|0
 18:12:37 -RM(2)/edges|+|3|-3|3|0|0
 18:12:37  RM(2)/edges|-|3|-3|2|2|2
 18:12:37 +RM(2)/edges|+|3|-3|3|0|0
 18:12:37  RM(2)/faces|-|2|SRID=4326;POLYGON((17 30,17 40,31 40,31 30,17
 30))
 18:12:37  NE(27)|27
 18:12:37 -NE(27)/edges|+|3|-27|3|10|10
 18:12:37  NE(27)/edges|-|3|-3|3|0|0
 18:12:37 +NE(27)/edges|+|3|-27|3|10|10
 18:12:37  NE(27)/edges|+|27|27|-3|0|10
 18:12:37  NE(27)/faces|+|10|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:37  RM(27)|0
 18:12:37 -RM(27)/edges|+|3|-3|3|0|0
 18:12:37  RM(27)/edges|-|3|-27|3|10|10
 18:12:37 +RM(27)/edges|+|3|-3|3|0|0
 18:12:37  RM(27)/edges|-|27|27|-3|0|10
 18:12:37  RM(27)/faces|-|10|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:37  NE(28)|28
 18:12:37 -NE(28)/edges|+|3|28|3|11|11
 18:12:37  NE(28)/edges|-|3|-3|3|0|0
 18:12:37 +NE(28)/edges|+|3|28|3|11|11
 18:12:37  NE(28)/edges|+|28|-3|-28|11|0
 18:12:37  NE(28)/faces|+|11|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:37  RM(28)|0
 18:12:37 -RM(28)/edges|+|3|-3|3|0|0
 18:12:37  RM(28)/edges|-|3|28|3|11|11
 18:12:37 +RM(28)/edges|+|3|-3|3|0|0
 18:12:37  RM(28)/edges|-|28|-3|-28|11|0
 18:12:37  RM(28)/faces|-|11|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:37  NE(29)|29
 18:12:37 -NE(29)/edges|+|3|-3|29|12|12
 18:12:37  NE(29)/edges|-|3|-3|3|0|0
 18:12:37 +NE(29)/edges|+|3|-3|29|12|12
 18:12:37  NE(29)/edges|+|29|3|-29|12|0
 18:12:37  NE(29)/faces|+|12|SRID=4326;POLYGON((22 30,22 37,28 37,28 30,22
 30))
 18:12:37  RM(29)|0
 18:12:37 -RM(29)/edges|+|3|-3|3|0|0
 18:12:37  RM(29)/edges|-|3|-3|29|12|12
 18:12:37 +RM(29)/edges|+|3|-3|3|0|0
 18:12:37  RM(29)/edges|-|29|3|-29|12|0
 18:12:37  RM(29)/faces|-|12|SRID=4326;POLYGON((22 30,22 37,28 37,28 30,22
 30))
 18:12:37  NE(30)|30
 18:12:37  NE(31)|31
 18:12:37 -NE(30,31)/nodes|+|4|
 18:12:37  NE(30,31)/nodes|-|4|0
 18:12:37 -NE(30,31)/edges|+|3|31|3|0|0
 18:12:37 +NE(30,31)/nodes|+|4|
 18:12:37  NE(30,31)/edges|-|3|-3|3|0|0
 18:12:37 +NE(30,31)/edges|+|3|31|3|0|0
 18:12:37  NE(30,31)/edges|+|30|-31|30|13|13
 18:12:37  NE(30,31)/edges|+|31|-3|-30|0|13
 18:12:37  NE(30,31)/faces|+|13|SRID=4326;POLYGON((18 35,18 40,25 40,25
 35,18 35))
 18:12:37  RM(31)|0
 18:12:37 -RM(31)/edges|+|3|-30|3|0|0
 18:12:37  RM(31)/edges|-|3|31|3|0|0
 18:12:37 -RM(31)/edges|+|30|-3|30|0|0
 18:12:37 +RM(31)/edges|+|3|-30|3|0|0
 18:12:37  RM(31)/edges|-|30|-31|30|13|13
 18:12:37 +RM(31)/edges|+|30|-3|30|0|0
 18:12:37  RM(31)/edges|-|31|-3|-30|0|13
 18:12:37  RM(31)/faces|-|13|SRID=4326;POLYGON((18 35,18 40,25 40,25 35,18
 35))
 18:12:37  NE(32)|32
 18:12:37 -NE(32)/edges|+|3|-32|3|14|14
 18:12:37  NE(32)/edges|-|3|-30|3|0|0
 18:12:37 -NE(32)/edges|+|30|-3|30|14|14
 18:12:37 +NE(32)/edges|+|3|-32|3|14|14
 18:12:37  NE(32)/edges|-|30|-3|30|0|0
 18:12:37 +NE(32)/edges|+|30|-3|30|14|14
 18:12:37  NE(32)/edges|+|32|32|-30|0|14
 18:12:37  NE(32)/faces|+|14|SRID=4326;POLYGON((18 27,18 40,28 40,28 27,18
 27))
 18:12:37  RM(32)|0
 18:12:37 -RM(32)/edges|+|3|-30|3|0|0
 18:12:37  RM(32)/edges|-|3|-32|3|14|14
 18:12:37 -RM(32)/edges|+|30|-3|30|0|0
 18:12:37 +RM(32)/edges|+|3|-30|3|0|0
 18:12:37  RM(32)/edges|-|30|-3|30|14|14
 18:12:37 +RM(32)/edges|+|30|-3|30|0|0
 18:12:37  RM(32)/edges|-|32|32|-30|0|14
 18:12:37  RM(32)/faces|-|14|SRID=4326;POLYGON((18 27,18 40,28 40,28 27,18
 27))
 18:12:37  NE(33)|33
 18:12:37 -NE(33)/edges|+|3|33|3|15|15
 18:12:37  NE(33)/edges|-|3|-30|3|0|0
 18:12:37 -NE(33)/edges|+|30|-3|30|15|15
 18:12:37 +NE(33)/edges|+|3|33|3|15|15
 18:12:37  NE(33)/edges|-|30|-3|30|0|0
 18:12:37 +NE(33)/edges|+|30|-3|30|15|15
 18:12:37  NE(33)/edges|+|33|-30|-33|15|0
 18:12:37  NE(33)/faces|+|15|SRID=4326;POLYGON((18 27,18 40,28 40,28 27,18
 27))
 18:12:37  RM(33)|0
 18:12:37 -RM(33)/edges|+|3|-30|3|0|0
 18:12:37  RM(33)/edges|-|3|33|3|15|15
 18:12:37 -RM(33)/edges|+|30|-3|30|0|0
 18:12:37 +RM(33)/edges|+|3|-30|3|0|0
 18:12:37  RM(33)/edges|-|30|-3|30|15|15
 18:12:37 +RM(33)/edges|+|30|-3|30|0|0
 18:12:37  RM(33)/edges|-|33|-30|-33|15|0
 18:12:37  RM(33)/faces|-|15|SRID=4326;POLYGON((18 27,18 40,28 40,28 27,18
 27))
 18:12:37  NE(34)|34
 18:12:37 -NE(34)/edges|+|3|-30|34|0|0
 18:12:37  NE(34)/edges|-|3|-30|3|0|0
 18:12:37 +NE(34)/edges|+|3|-30|34|0|0
 18:12:37  NE(34)/edges|+|34|3|-34|0|16
 18:12:37  NE(34)/faces|+|16|SRID=4326;POLYGON((22 27,22 30,28 30,28 27,22
 27))
 18:12:37  RM(34)|0
 18:12:37 -RM(34)/edges|+|3|-30|3|0|0
 18:12:37  RM(34)/edges|-|3|-30|34|0|0
 18:12:37 +RM(34)/edges|+|3|-30|3|0|0
 18:12:37  RM(34)/edges|-|34|3|-34|0|16
 18:12:37  RM(34)/faces|-|16|SRID=4326;POLYGON((22 27,22 30,28 30,28 27,22
 27))
 18:12:37  NE(35)|35
 18:12:37 -NE(35)/edges|+|3|-30|-35|0|0
 18:12:37  NE(35)/edges|-|3|-30|3|0|0
 18:12:37 +NE(35)/edges|+|3|-30|-35|0|0
 18:12:37  NE(35)/edges|+|35|35|3|17|0
 18:12:37  NE(35)/faces|+|17|SRID=4326;POLYGON((22 27,22 30,28 30,28 27,22
 27))
 18:12:37  RM(35)|0
 18:12:37 -RM(35)/edges|+|3|-30|3|0|0
 18:12:37  RM(35)/edges|-|3|-30|-35|0|0
 18:12:37 +RM(35)/edges|+|3|-30|3|0|0
 18:12:37  RM(35)/edges|-|35|35|3|17|0
 18:12:37  RM(35)/faces|-|17|SRID=4326;POLYGON((22 27,22 30,28 30,28 27,22
 27))
 18:12:37  Topology 'city_data' dropped
 18:12:37
 18:12:37  topology/test/regress/st_remedgenewface .. failed (diff expected
 obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_210_diff)
 18:12:38
 18:12:38 --- ./topology/test/regress/st_remedgenewface_expected 2023-01-30
 15:52:20.222179892 +0000
 18:12:38 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_210_out
 2023-04-20 22:12:38.396018557 +0000
 18:12:38 @@ -4,205 +4,205 @@
 18:12:38  ERROR:  SQL/MM Spatial exception - non-existent edge 0
 18:12:38  ERROR:  SQL/MM Spatial exception - non-existent edge 143
 18:12:38  RN(25)|
 18:12:38 -RN(25)/nodes|+|21|1
 18:12:38  RN(25)/nodes|-|21|
 18:12:38 -RN(25)/nodes|+|22|1
 18:12:38 +RN(25)/nodes|+|21|1
 18:12:38  RN(25)/nodes|-|22|
 18:12:38 +RN(25)/nodes|+|22|1
 18:12:38  RN(25)/edges|-|25|-25|25|1|1
 18:12:38  RN(4)|
 18:12:38 -RN(4)/nodes|+|5|0
 18:12:38  RN(4)/nodes|-|5|
 18:12:38 +RN(4)/nodes|+|5|0
 18:12:38  RN(4)/edges|-|4|-5|4|0|0
 18:12:38 -RN(4)/edges|+|5|-5|5|0|0
 18:12:38  RN(4)/edges|-|5|-4|5|0|0
 18:12:38 +RN(4)/edges|+|5|-5|5|0|0
 18:12:38  RN(26)|10
 18:12:38 -RN(26)/nodes|+|20|10
 18:12:38  RN(26)/nodes|-|20|
 18:12:38 -RN(26)/nodes|+|21|10
 18:12:38 +RN(26)/nodes|+|20|10
 18:12:38  RN(26)/nodes|-|21|1
 18:12:38 -RN(26)/nodes|+|22|10
 18:12:38 +RN(26)/nodes|+|21|10
 18:12:38  RN(26)/nodes|-|22|1
 18:12:38 -RN(26)/edges|+|1|1|-1|10|0
 18:12:38 +RN(26)/nodes|+|22|10
 18:12:38  RN(26)/edges|-|1|1|-1|1|0
 18:12:38 +RN(26)/edges|+|1|1|-1|10|0
 18:12:38  RN(26)/edges|-|26|26|-26|9|1
 18:12:38  RN(26)/faces|-|1|SRID=4326;POLYGON((3 30,3 38,16 38,16 30,3 30))
 18:12:38  RN(26)/faces|-|9|SRID=4326;POLYGON((4 31,4 34,7 34,7 31,4 31))
 18:12:38  RN(26)/faces|+|10|SRID=4326;POLYGON((3 30,3 38,16 38,16 30,3
 30))
 18:12:38  RN(9)|11
 18:12:38 -RN(9)/edges|+|6|7|-21|0|11
 18:12:38  RN(9)/edges|-|6|7|-21|0|3
 18:12:38 +RN(9)/edges|+|6|7|-21|0|11
 18:12:38  RN(9)/edges|-|9|19|-22|3|6
 18:12:38 -RN(9)/edges|+|12|20|22|11|0
 18:12:38  RN(9)/edges|-|12|20|22|6|0
 18:12:38 -RN(9)/edges|+|19|-6|-10|11|4
 18:12:38 +RN(9)/edges|+|12|20|22|11|0
 18:12:38  RN(9)/edges|-|19|-6|-10|3|4
 18:12:38 -RN(9)/edges|+|20|19|13|11|7
 18:12:38 +RN(9)/edges|+|19|-6|-10|11|4
 18:12:38  RN(9)/edges|-|20|-9|13|6|7
 18:12:38 -RN(9)/edges|+|21|6|-22|0|11
 18:12:38 +RN(9)/edges|+|20|19|13|11|7
 18:12:38  RN(9)/edges|-|21|6|9|0|3
 18:12:38 -RN(9)/edges|+|22|21|12|0|11
 18:12:38 +RN(9)/edges|+|21|6|-22|0|11
 18:12:38  RN(9)/edges|-|22|21|12|0|6
 18:12:38 +RN(9)/edges|+|22|21|12|0|11
 18:12:38  RN(9)/faces|-|3|SRID=4326;POLYGON((9 14,9 22,21 22,21 14,9 14))
 18:12:38  RN(9)/faces|-|6|SRID=4326;POLYGON((9 6,9 14,21 14,21 6,9 6))
 18:12:38  RN(9)/faces|+|11|SRID=4326;POLYGON((9 6,9 22,21 22,21 6,9 6))
 18:12:38  RN(19)|12
 18:12:38 -RN(19)/edges|+|6|7|-21|0|12
 18:12:38  RN(19)/edges|-|6|7|-21|0|11
 18:12:38 -RN(19)/edges|+|7|8|-6|0|12
 18:12:38 +RN(19)/edges|+|6|7|-21|0|12
 18:12:38  RN(19)/edges|-|7|8|-19|0|4
 18:12:38 -RN(19)/edges|+|10|-20|17|7|12
 18:12:38 +RN(19)/edges|+|7|8|-6|0|12
 18:12:38  RN(19)/edges|-|10|-20|17|7|4
 18:12:38 -RN(19)/edges|+|12|20|22|12|0
 18:12:38 +RN(19)/edges|+|10|-20|17|7|12
 18:12:38  RN(19)/edges|-|12|20|22|11|0
 18:12:38 -RN(19)/edges|+|17|-7|11|12|5
 18:12:38 +RN(19)/edges|+|12|20|22|12|0
 18:12:38  RN(19)/edges|-|17|-7|11|4|5
 18:12:38 +RN(19)/edges|+|17|-7|11|12|5
 18:12:38  RN(19)/edges|-|19|-6|-10|11|4
 18:12:38 -RN(19)/edges|+|20|-10|13|12|7
 18:12:38  RN(19)/edges|-|20|19|13|11|7
 18:12:38 -RN(19)/edges|+|21|6|-22|0|12
 18:12:38 +RN(19)/edges|+|20|-10|13|12|7
 18:12:38  RN(19)/edges|-|21|6|-22|0|11
 18:12:38 -RN(19)/edges|+|22|21|12|0|12
 18:12:38 +RN(19)/edges|+|21|6|-22|0|12
 18:12:38  RN(19)/edges|-|22|21|12|0|11
 18:12:38 +RN(19)/edges|+|22|21|12|0|12
 18:12:38  RN(19)/faces|-|4|SRID=4326;POLYGON((21 14,21 22,35 22,35 14,21
 14))
 18:12:38  RN(19)/faces|-|11|SRID=4326;POLYGON((9 6,9 22,21 22,21 6,9 6))
 18:12:38  RN(19)/faces|+|12|SRID=4326;POLYGON((9 6,9 22,35 22,35 6,9 6))
 18:12:38  RN(10)|13
 18:12:38 -RN(10)/edges|+|6|7|-21|0|13
 18:12:38  RN(10)/edges|-|6|7|-21|0|12
 18:12:38 -RN(10)/edges|+|7|8|-6|0|13
 18:12:38 +RN(10)/edges|+|6|7|-21|0|13
 18:12:38  RN(10)/edges|-|7|8|-6|0|12
 18:12:38 +RN(10)/edges|+|7|8|-6|0|13
 18:12:38  RN(10)/edges|-|10|-20|17|7|12
 18:12:38 -RN(10)/edges|+|12|20|22|13|0
 18:12:38  RN(10)/edges|-|12|20|22|12|0
 18:12:38 -RN(10)/edges|+|13|18|-12|13|0
 18:12:38 +RN(10)/edges|+|12|20|22|13|0
 18:12:38  RN(10)/edges|-|13|18|-12|7|0
 18:12:38 -RN(10)/edges|+|17|-7|11|13|5
 18:12:38 +RN(10)/edges|+|13|18|-12|13|0
 18:12:38  RN(10)/edges|-|17|-7|11|12|5
 18:12:38 -RN(10)/edges|+|18|17|14|13|8
 18:12:38 +RN(10)/edges|+|17|-7|11|13|5
 18:12:38  RN(10)/edges|-|18|10|14|7|8
 18:12:38 -RN(10)/edges|+|20|-20|13|13|13
 18:12:38 +RN(10)/edges|+|18|17|14|13|8
 18:12:38  RN(10)/edges|-|20|-10|13|12|7
 18:12:38 -RN(10)/edges|+|21|6|-22|0|13
 18:12:38 +RN(10)/edges|+|20|-20|13|13|13
 18:12:38  RN(10)/edges|-|21|6|-22|0|12
 18:12:38 -RN(10)/edges|+|22|21|12|0|13
 18:12:38 +RN(10)/edges|+|21|6|-22|0|13
 18:12:38  RN(10)/edges|-|22|21|12|0|12
 18:12:38 +RN(10)/edges|+|22|21|12|0|13
 18:12:38  RN(10)/faces|-|7|SRID=4326;POLYGON((21 6,21 14,35 14,35 6,21 6))
 18:12:38  RN(10)/faces|-|12|SRID=4326;POLYGON((9 6,9 22,35 22,35 6,9 6))
 18:12:38  RN(10)/faces|+|13|SRID=4326;POLYGON((9 6,9 22,35 22,35 6,9 6))
 18:12:38  RN(20)|
 18:12:38 -RN(20)/nodes|+|14|13
 18:12:38  RN(20)/nodes|-|14|
 18:12:38 -RN(20)/edges|+|12|13|22|13|0
 18:12:38 +RN(20)/nodes|+|14|13
 18:12:38  RN(20)/edges|-|12|20|22|13|0
 18:12:38 +RN(20)/edges|+|12|13|22|13|0
 18:12:38  RN(20)/edges|-|20|-20|13|13|13
 18:12:38  RN(15)|
 18:12:38 -RN(15)/edges|+|8|-8|-17|0|0
 18:12:38  RN(15)/edges|-|8|-15|-17|0|5
 18:12:38 -RN(15)/edges|+|11|-16|-18|0|8
 18:12:38 +RN(15)/edges|+|8|-8|-17|0|0
 18:12:38  RN(15)/edges|-|11|15|-18|5|8
 18:12:38 +RN(15)/edges|+|11|-16|-18|0|8
 18:12:38  RN(15)/edges|-|15|-8|-16|5|0
 18:12:38 -RN(15)/edges|+|17|-7|11|13|0
 18:12:38  RN(15)/edges|-|17|-7|11|13|5
 18:12:38 +RN(15)/edges|+|17|-7|11|13|0
 18:12:38  RN(15)/faces|-|5|SRID=4326;POLYGON((35 14,35 22,47 22,47 14,35
 14))
 18:12:38  RN(2)|
 18:12:38 -RN(2)/nodes|+|4|0
 18:12:38  RN(2)/nodes|-|4|2
 18:12:38 +RN(2)/nodes|+|4|0
 18:12:38  RN(2)/edges|-|2|3|-2|2|0
 18:12:38 -RN(2)/edges|+|3|-3|3|0|0
 18:12:38  RN(2)/edges|-|3|-3|2|2|2
 18:12:38 +RN(2)/edges|+|3|-3|3|0|0
 18:12:38  RN(2)/faces|-|2|SRID=4326;POLYGON((17 30,17 40,31 40,31 30,17
 30))
 18:12:38  NE(27)|27
 18:12:38 -NE(27)/edges|+|3|-27|3|14|14
 18:12:38  NE(27)/edges|-|3|-3|3|0|0
 18:12:38 +NE(27)/edges|+|3|-27|3|14|14
 18:12:38  NE(27)/edges|+|27|27|-3|0|14
 18:12:38  NE(27)/faces|+|14|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:38  RN(27)|
 18:12:38 -RN(27)/edges|+|3|-3|3|0|0
 18:12:38  RN(27)/edges|-|3|-27|3|14|14
 18:12:38 +RN(27)/edges|+|3|-3|3|0|0
 18:12:38  RN(27)/edges|-|27|27|-3|0|14
 18:12:38  RN(27)/faces|-|14|SRID=4326;POLYGON((20 27,20 35,30 35,30 27,20
 27))
 18:12:38  NE(28)|28
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5375>
