[postgis-tickets] [PostGIS] #5374: PG16 failing unrecognized configuration parameter "force_parallel_mode"
PostGIS trac at osgeo.org
Fri Apr 21 21:17:18 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  3.3.x
Resolution:  fixed    |   Keywords:  PostgreSQL 16 pg16
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"76f44dea83e09101c2fa949b0ad8bfb00494449b/git" 76f44de/git]:
 {{{#!CommitTicketReference repository="git"
 revision="76f44dea83e09101c2fa949b0ad8bfb00494449b"
 Support build on Pg16devel for PostGIS 3.3.3
 Closes #5257
 Closes #5261
 Closes #5277
 Closes #5308
 Closes #5374
 Closes https://github.com/postgis/postgis/pull/716
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5374#comment:6>
