[postgis-tickets] [PostGIS] #5374: PG16 failing unrecognized configuration parameter "force_parallel_mode"
PostGIS trac at osgeo.org
Fri Apr 21 12:51:04 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:  PostgreSQL 16 pg16
Comment (by robe):
 An alternative to using procedure would have been to use update as
 RhodiumToad (Andrew) suggested on IRC.
 update pg_settings set setting = 'on' where name in
 ('debug_parallel_query','force_parallel_mode');
 Then version wouldn't matter.  Right now can only be backported to 3.3
 since I'm using procedures introduced in PG 11
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5374#comment:5>
