[postgis-tickets] [PostGIS] #5374: PG16 failing unrecognized configuration parameter "force_parallel_mode"
PostGIS trac at osgeo.org
Thu Apr 20 22:49:53 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:  PostgreSQL 16 pg16
Comment (by Regina Obe <lr@…>):
 In [changeset:"bff92ecda241ea8227b1b509370d7219fadc2314/git"
 bff92ecd/git]:
 {{{#!CommitTicketReference repository="git"
 revision="bff92ecda241ea8227b1b509370d7219fadc2314"
 PG16 regression fixes
  - Use debug_parallel_query
    instead of force_parallel_mode for PG16 and above
  - Address PG16 sorting of text behavior change for (tickets)
  References #5374 for PostGIS 3.4.0
  References #5475 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5374#comment:4>
