[postgis-tickets] [PostGIS] #5362: ERROR in ST_Intersects
PostGIS trac at osgeo.org
Sat Apr 22 13:32:33 PDT 2023
  Reporter:  tomasmarek  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.3.3
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:  ST_Intersects
Comment (by robe):
 This does seem weird that ST_Intersects would trigger an error but
 ST_Intersection would not.
 However I can't replicate your issue with these geometries when running:
 POSTGIS="3.3.3dev 3.3.2-47-g76f44dea8" [EXTENSION] PGSQL="160" GEOS="3.12
 .0dev-CAPI-1.18.0" PROJ="7.2.1" LIBXML="2.9.14" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" PostgreSQL 16devel on
 x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by
 MinGW-W64 project) 8.1.0, 64-bit
 So I suspect it's geos dependent and perhaps an issue that has already
 been fixed in GEOS.
 Can you output what:
 SELECT postgis_full_version();
 returns
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5362#comment:1>
