[postgis-tickets] [PostGIS] #5362: ERROR in ST_Intersects
PostGIS trac at osgeo.org
Sat Apr 22 14:01:28 PDT 2023
  Reporter:  tomasmarek  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.3.3
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:  ST_Intersects
Comment (by mdavis):
 In GEOS 3.12 `intersects` has [https://github.com/libgeos/geos/pull/775
 changed] to use the `PreparedIntersects` algorithm, since it is faster and
 more robust.
 Older versions of GEOS (likely including all installed versions) use the
 original `intersects` algorithm, which does fail on this case (due to
 numeric precision issues).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5362#comment:2>
