[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-745-gbef103b65
Thu Apr 27 08:48:58 PDT 2023
the project "PostGIS".
       via  bef103b65ccb5f5ed6f4a8bb346a6e4c95c72d0e (commit)
      from  04b747974e2d0c35a568281edf6e3f61bf329cbf (commit)
revisions in full, below.
commit bef103b65ccb5f5ed6f4a8bb346a6e4c95c72d0e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 27 08:48:54 2023 -0700
    Preserve input SRID in SQL wrapper to synthetic buffer, closes #5378
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index f7e130074..948d7d4e5 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -641,55 +641,6 @@ CREATE OR REPLACE FUNCTION _ST_BestSRID(geography)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
--- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
-	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
--- Availability: 2.3.x
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
-	RETURNS geography
--- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
-	RETURNS geometry AS
-	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2);  $$
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
-	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
-CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
-CREATE OR REPLACE FUNCTION ST_Intersection(text, text)
-	$$ SELECT @extschema at .ST_Intersection($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
-	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_AsBinary(geography)
 	RETURNS bytea
@@ -832,6 +783,55 @@ CREATE OR REPLACE FUNCTION ST_Intersects(geog1 geography, geog2 geography)
 	_COST_HIGH;
+-- Availability: 1.5.0
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2), @extschema at .ST_SRID($1)))'
+	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+-- Availability: 2.3.x
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), @extschema at .ST_SRID($1)))'
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
+	RETURNS geography
+-- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
+	RETURNS geometry AS
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2);  $$
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
+CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), @extschema at .ST_SRID($1)))'
+CREATE OR REPLACE FUNCTION ST_Intersection(text, text)
+	$$ SELECT @extschema at .ST_Intersection($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_Covers(text, text)
 	RETURNS boolean AS
@@ -859,3 +859,4 @@ CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
Summary of changes:
 postgis/geography.sql.in | 99 ++++++++++++++++++++++++------------------------
 1 file changed, 50 insertions(+), 49 deletions(-)
hooks/post-receive
