[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-53-g15a1827e8
Thu Apr 27 09:08:20 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  15a1827e88eb8ef8e021d73c6952b5f6123f1b7f (commit)
      from  1abb3e420b59a4bdb71becda56dfcf4ec947b842 (commit)
revisions in full, below.
commit 15a1827e88eb8ef8e021d73c6952b5f6123f1b7f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 27 09:08:15 2023 -0700
    Retain SRID through ST_Buffer(geography) call, references #5378
diff --git a/NEWS b/NEWS
index 80d3a40a0..46ab40575 100644
--- a/NEWS
+++ b/NEWS
@@ -26,6 +26,7 @@ YYYY/MM/DD
   - #5257, #5261, #5277, #5304, #5308, #5374, Support for PG16
           (Paul Ramsey, Regina Obe, Sandro , Laurenz Albe)
   - #5371, ST_Union segfaults (PG 11-12) (Regina Obe)
+  - #5378, ST_Buffer(geography) drops SRID (Paul Ramsey)
 PostGIS 3.3.2
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index c48a4117d..c0ccb9ccc 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -641,55 +641,6 @@ CREATE OR REPLACE FUNCTION _ST_BestSRID(geography)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
--- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
-	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
--- Availability: 2.3.x
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
-CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
-	RETURNS geography
--- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
-	RETURNS geometry AS
-	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2);  $$
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
-	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
-CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
-CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
-	RETURNS geography
-	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
-CREATE OR REPLACE FUNCTION ST_Intersection(text, text)
-	$$ SELECT @extschema at .ST_Intersection($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
-	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_AsBinary(geography)
 	RETURNS bytea
@@ -865,6 +816,59 @@ CREATE OR REPLACE FUNCTION ST_Intersects(geography, geography)
 #endif /* POSTGIS_PGSQL_VERSION < 120 */
+-- Availability: 1.5.0
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2), @extschema at .ST_SRID($1)))'
+	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+-- Availability: 2.3.x
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), @extschema at .ST_SRID($1)))'
+CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
+	RETURNS geography
+-- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
+	RETURNS geometry AS
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2);  $$
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
+CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
+CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
+	RETURNS geography
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), @extschema at .ST_SRID($1)))'
+CREATE OR REPLACE FUNCTION ST_Intersection(text, text)
+	$$ SELECT @extschema at .ST_Intersection($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	_COST_HIGH;
 CREATE OR REPLACE FUNCTION ST_Covers(text, text)
 	RETURNS boolean AS
Summary of changes:
 NEWS                     |   1 +
 postgis/geography.sql.in | 102 ++++++++++++++++++++++++-----------------------
 2 files changed, 54 insertions(+), 49 deletions(-)
hooks/post-receive
