[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta2-20-g120e82322
Thu Aug 3 13:25:06 PDT 2023
the project "PostGIS".
       via  120e8232235d813a55284fd97eeac4bf2ec0ea78 (commit)
      from  632d836163931f8f0185c102d1b40f24be305144 (commit)
revisions in full, below.
commit 120e8232235d813a55284fd97eeac4bf2ec0ea78
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Aug 3 16:23:24 2023 -0400
    TURN OFF check-xml except for ja, de, fr
    Other languages are so far behind, it's a waste of time checking
    and takes 6 minutes for each language checked
    Closes #5466
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index b8a387b3b..3524294b5 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -84,52 +84,52 @@ steps:
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
 ### TARGET check-xml
-  check-xml-it_IT:
-    image: *test_image
-    commands:
-      - make -C build-docs/doc/po/it_IT local-check-xml
-    group: localized-check-xml
-    when:
-      path:
-        include:
-          # Localized assets
-          - "doc/po/it_IT/Makefile.in"
-          - "doc/po/it_IT/*.po"
-          - "utils/check_localized_cheatsheets.sh"
-          # Common docs path
-          # related config files
-          - ".woodpecker/docs.yml"
-          # Makefiles
-          - "doc/Makefile.in"
-          - "doc/html/images/Makefile.in"
-          # XML sources
-          - "doc/*.xml"
-          # Internationalization Makefiles
-          - "doc/po/Makefile.local"
-          # END OF COMMON PATHS
-  check-xml-pt_BR:
-    commands:
-      - make -C build-docs/doc/po/pt_BR local-check-xml
-    when:
-      path:
-        include:
-          - "doc/po/pt_BR/Makefile.in"
-          - "doc/po/pt_BR/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
+  # check-xml-it_IT:
+  #   image: *test_image
+  #   commands:
+  #     - make -C build-docs/doc/po/it_IT local-check-xml
+  #   group: localized-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         # Localized assets
+  #         - "doc/po/it_IT/Makefile.in"
+  #         - "doc/po/it_IT/*.po"
+  #         - "utils/check_localized_cheatsheets.sh"
+  #         # Common docs path
+  #         # related config files
+  #         - ".woodpecker/docs.yml"
+  #         # Makefiles
+  #         - "doc/Makefile.in"
+  #         - "doc/html/images/Makefile.in"
+  #         # XML sources
+  #         - "doc/*.xml"
+  #         # Internationalization Makefiles
+  #         - "doc/po/Makefile.local"
+  #         # END OF COMMON PATHS
+  # check-xml-pt_BR:
+  #   commands:
+  #     - make -C build-docs/doc/po/pt_BR local-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         - "doc/po/pt_BR/Makefile.in"
+  #         - "doc/po/pt_BR/*.po"
+  #         # Makefiles
+  #         # XML sources
+  #         - "doc/*.xml"
   check-xml-fr:
     image: *test_image
     commands:
@@ -153,75 +153,75 @@ steps:
-  check-xml-es:
-    commands:
-      - make -C build-docs/doc/po/es local-check-xml
-    when:
-      path:
-        include:
-          - "doc/po/es/Makefile.in"
-          - "doc/po/es/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
-  check-xml-pl:
-    commands:
-      - make -C build-docs/doc/po/pl local-check-xml
-    when:
-      path:
-        include:
-          - "doc/po/pl/Makefile.in"
-          - "doc/po/pl/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
-  check-xml-ko_KR:
-    commands:
-      - make -C build-docs/doc/po/ko_KR local-check-xml
-    when:
-      path:
-        include:
-          - "doc/po/ko_KR/Makefile.in"
-          - "doc/po/ko_KR/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
+  # check-xml-es:
+  #   commands:
+  #     - make -C build-docs/doc/po/es local-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         - "doc/po/es/Makefile.in"
+  #         - "doc/po/es/*.po"
+  #         # Makefiles
+  #         # XML sources
+  #         - "doc/*.xml"
+  # check-xml-pl:
+  #   commands:
+  #     - make -C build-docs/doc/po/pl local-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         - "doc/po/pl/Makefile.in"
+  #         - "doc/po/pl/*.po"
+  #         # Makefiles
+  #         # XML sources
+  #         - "doc/*.xml"
+  # check-xml-ko_KR:
+  #   commands:
+  #     - make -C build-docs/doc/po/ko_KR local-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         - "doc/po/ko_KR/Makefile.in"
+  #         - "doc/po/ko_KR/*.po"
+  #         # Makefiles
+  #         # XML sources
+  #         - "doc/*.xml"
   check-xml-de:
     image: *test_image
     commands:
@@ -268,29 +268,29 @@ steps:
-  check-xml-ru:
-    commands:
-      - make -C build-docs/doc/po/ru local-check-xml
-    when:
-      path:
-        include:
-          - "doc/po/ru/Makefile.in"
-          - "doc/po/ru/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
+  # check-xml-ru:
+  #   commands:
+  #     - make -C build-docs/doc/po/ru local-check-xml
+  #   when:
+  #     path:
+  #       include:
+  #         - "doc/po/ru/Makefile.in"
+  #         - "doc/po/ru/*.po"
+  #         # Makefiles
+  #         # XML sources
+  #         - "doc/*.xml"
 ### TARGET html
   html-it_IT:
     image: *test_image
Summary of changes:
 .woodpecker/docs.yml | 276 +++++++++++++++++++++++++--------------------------
 1 file changed, 138 insertions(+), 138 deletions(-)
hooks/post-receive
