[postgis-tickets] [PostGIS] #5466: Turn off doc checks on translations that are far from done
PostGIS trac at osgeo.org
Tue Aug 8 05:01:36 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 The docs.yml content after the `DO NOT EDIT` line is generated from
 .woodpecker/update-docs-localized.sh so that's where laguages should be
 skipped, if at all.
 The conditionals should result in ONLY building the localized languages
 that are actually translated so it shoudln't be a huge deal to keep them
 all.
 See https://git.osgeo.org/gitea/postgis/postgis/pulls/135 for how
 languages could be skip, if there's a compelling reason to do so
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5466#comment:5>
