[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta2-24-g4838f1843
git at osgeo.org
git at osgeo.org
Sat Aug 5 14:42:35 PDT 2023
the project "PostGIS".
via 4838f18435a62d337f29ce5575477a461477ae16 (commit)
via f56fb33186a953082071d752c09c5c0a1f9034e2 (commit)
via 5620f2bf7afbf411cb567406945981eea13cd176 (commit)
from af3e63085419434590f2d52963ca89105e52492f (commit)
revisions in full, below.
commit 4838f18435a62d337f29ce5575477a461477ae16
Author: Regina Obe <lr at pcorp.us>
Date: Sat Aug 5 17:41:14 2023 -0400
Credits for #5442
References https://git.osgeo.org/gitea/postgis/postgis/pulls/134
diff --git a/NEWS b/NEWS
index 64d213258..aa11c066f 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,11 @@
PostGIS 3.4.0rc1
-2023/xx/xx
+2023/08/05
+Changes since 3.4.0beta2 release
+ - #5442, [postgis_tiger_geocoder,postgis_topology]
+ Database search_path does not do
+ what it intends to do (Jelte Fennema)
PostGIS 3.4.0beta2
2023/07/29
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 97d1ff783..b487787d0 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -266,6 +266,7 @@
<member>Jan Katins</member>
<member>Jason Smith</member>
<member>Jeff Adams</member>
+ <member>Jelte Fennema</member>
<member>Jim Jones</member>
<member>Joe Conway</member>
<member>Jonne Savolainen</member>
commit f56fb33186a953082071d752c09c5c0a1f9034e2
Date: Sat Aug 5 17:31:51 2023 -0400
Remove more uncommon language builds
References #5466 for PostGIS 3.4.0
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index c0dd942c5..ef09eacaf 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -361,52 +361,52 @@ steps:
# Internationalization Makefiles
- "doc/po/Makefile.local"
# END OF COMMON PATHS
- html-es:
- image: *test_image
- commands:
- - make -C build-docs/doc/po/es local-html
- group: localized-html
- when:
- path:
- include:
- # Localized assets
- - "doc/po/es/Makefile.in"
- - "doc/po/es/*.po"
- - "utils/check_localized_cheatsheets.sh"
- # Common docs path
- # related config files
- - ".woodpecker/docs.yml"
- # Makefiles
- - "doc/Makefile.in"
- - "doc/html/images/Makefile.in"
- # XML sources
- - "doc/*.xml"
- # Internationalization Makefiles
- - "doc/po/Makefile.local"
- # END OF COMMON PATHS
- html-pl:
- commands:
- - make -C build-docs/doc/po/pl local-html
- when:
- path:
- include:
- - "doc/po/pl/Makefile.in"
- - "doc/po/pl/*.po"
- # Makefiles
- # XML sources
- - "doc/*.xml"
+ # html-es:
+ # image: *test_image
+ # commands:
+ # - make -C build-docs/doc/po/es local-html
+ # group: localized-html
+ # when:
+ # path:
+ # include:
+ # # Localized assets
+ # - "doc/po/es/Makefile.in"
+ # - "doc/po/es/*.po"
+ # - "utils/check_localized_cheatsheets.sh"
+ # # Common docs path
+ # # related config files
+ # - ".woodpecker/docs.yml"
+ # # Makefiles
+ # - "doc/Makefile.in"
+ # - "doc/html/images/Makefile.in"
+ # # XML sources
+ # - "doc/*.xml"
+ # # Internationalization Makefiles
+ # - "doc/po/Makefile.local"
+ # # END OF COMMON PATHS
+ # html-pl:
+ # commands:
+ # - make -C build-docs/doc/po/pl local-html
+ # when:
+ # path:
+ # include:
+ # - "doc/po/pl/Makefile.in"
+ # - "doc/po/pl/*.po"
+ # # Makefiles
+ # # XML sources
+ # - "doc/*.xml"
html-ko_KR:
image: *test_image
commands:
@@ -476,29 +476,29 @@ steps:
- html-ru:
- commands:
- - make -C build-docs/doc/po/ru local-html
- when:
- path:
- include:
- - "doc/po/ru/Makefile.in"
- - "doc/po/ru/*.po"
- # Makefiles
- # XML sources
- - "doc/*.xml"
+ # html-ru:
+ # commands:
+ # - make -C build-docs/doc/po/ru local-html
+ # when:
+ # path:
+ # include:
+ # - "doc/po/ru/Makefile.in"
+ # - "doc/po/ru/*.po"
+ # # Makefiles
+ # # XML sources
+ # - "doc/*.xml"
### TARGET cheatsheets
cheatsheets-it_IT:
image: *test_image
@@ -592,29 +592,29 @@ steps:
- cheatsheets-pl:
- commands:
- - make -C build-docs/doc/po/pl local-cheatsheets
- group: localized-cheatsheets
- when:
- path:
- include:
- # Makefiles
- # XML sources
- - "doc/*.xml"
+ # cheatsheets-pl:
+ # commands:
+ # - make -C build-docs/doc/po/pl local-cheatsheets
+ # group: localized-cheatsheets
+ # when:
+ # path:
+ # include:
+ # # Makefiles
+ # # XML sources
+ # - "doc/*.xml"
cheatsheets-ko_KR:
image: *test_image
commands:
@@ -985,29 +985,29 @@ steps:
- pdf-es:
- commands:
- - make -C build-docs/doc/po/es local-pdf
- group: localized-pdf
- when:
- path:
- include:
- # Makefiles
- # XML sources
- - "doc/*.xml"
+ # pdf-es:
+ # commands:
+ # - make -C build-docs/doc/po/es local-pdf
+ # group: localized-pdf
+ # when:
+ # path:
+ # include:
+ # # Makefiles
+ # # XML sources
+ # - "doc/*.xml"
# pdf-pl:
# commands:
commit 5620f2bf7afbf411cb567406945981eea13cd176
Author: Jelte Fennema <github-tech at jeltef.nl>
Date: Fri Jul 14 12:37:52 2023 +0200
Fix add to search_path
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 5fa7bde72..a984ecb92 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -126,7 +126,16 @@ BEGIN
RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
IF var_cur_search_path IS NULL THEN
- SELECT reset_val
+ SELECT setting
+ INTO var_cur_search_path
+ FROM pg_catalog.pg_file_settings
+ WHERE name OPERATOR(pg_catalog.=) 'search_path' AND applied;
+ RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
+ END IF;
+ IF var_cur_search_path IS NULL THEN
+ SELECT boot_val
FROM pg_catalog.pg_settings
WHERE name OPERATOR(pg_catalog.=) 'search_path';
@@ -134,7 +143,6 @@ BEGIN
RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
END IF;
IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
ELSE
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index 2acfd9c41..eb9da2d02 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -25,18 +25,50 @@ DECLARE
var_result text;
var_cur_search_path text;
BEGIN
- SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
- IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
- var_result := a_schema_name || ' already in database search_path';
+ WITH settings AS (
+ SELECT pg_catalog.unnest(setconfig) config
+ FROM pg_catalog.pg_db_role_setting
+ WHERE setdatabase OPERATOR(pg_catalog.=) (
+ SELECT oid
+ FROM pg_catalog.pg_database
+ WHERE datname OPERATOR(pg_catalog.=) pg_catalog.current_database()
+ ) and setrole OPERATOR(pg_catalog.=) 0
+ SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
+ FROM settings WHERE config like 'search_path=%'
+ INTO var_cur_search_path;
+ RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
+ SELECT setting
+ END IF;
+ SELECT boot_val
+ FROM pg_catalog.pg_settings
+ WHERE name OPERATOR(pg_catalog.=) 'search_path';
+ RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
+ END IF;
+ IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
+ var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
ELSE
- var_cur_search_path := var_cur_search_path || ', '
- || pg_catalog.quote_ident(a_schema_name);
- EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
- || ' SET search_path = ' || var_cur_search_path;
- var_result := a_schema_name || ' has been added to end of database search_path ';
+ var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
+ OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
+ EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
+ OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
+ var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
END IF;
- EXECUTE 'SET search_path = ' || var_cur_search_path;
+ EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
RETURN var_result;
END
Summary of changes:
.woodpecker/docs.yml | 230 ++++++++++++++++----------------
NEWS | 8 +-
doc/introduction.xml | 1 +
extensions/postgis_extension_helper.sql | 12 +-
topology/sql/manage/ManageHelper.sql.in | 50 +++++--
5 files changed, 174 insertions(+), 127 deletions(-)
hooks/post-receive
