[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.4-6-ga514af682
Sat Aug 5 14:58:21 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  a514af682b38c7b329ec50dd7ffa15d3e3bcbacd (commit)
      from  e06d678ee856912a7627a23d8e92a7bc0ae745dc (commit)
revisions in full, below.
commit a514af682b38c7b329ec50dd7ffa15d3e3bcbacd
Author: Jelte Fennema <github-tech at jeltef.nl>
Date:   Fri Jul 14 12:37:52 2023 +0200
    Fix add to search_path (Jelte Fennema)
    Closes #5442 for PostGIS 3.3.5
    Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/134
diff --git a/NEWS b/NEWS
index 3e0ef6110..57ded465a 100644
--- a/NEWS
+++ b/NEWS
@@ -2,7 +2,9 @@ PostGIS 3.3.5dev
 YYYY/MM/DD
 * Bug Fixes and Enhancements *
+ - #5442, [postgis_tiger_geocoder,postgis_topology]
+          Database search_path does not do
+          what it intends to do (Jelte Fennema)
 PostGIS 3.3.4
 2023/07/28
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 1ed7fa4f2..8d1407ad0 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -262,6 +262,7 @@
                     <member>Jan Katins</member>
 					<member>Jason Smith</member>
 					<member>Jeff Adams</member>
+                    <member>Jelte Fennema</member>
                     <member>Jim Jones</member>
                     <member>Joe Conway</member>
 					<member>Jonne Savolainen</member>
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 5fa7bde72..a984ecb92 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -126,7 +126,16 @@ BEGIN
 	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
 	IF var_cur_search_path IS NULL THEN
-		SELECT reset_val
+		SELECT setting
+		INTO var_cur_search_path
+		FROM pg_catalog.pg_file_settings
+		WHERE name OPERATOR(pg_catalog.=) 'search_path' AND applied;
+		RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
+	END IF;
+	IF var_cur_search_path IS NULL THEN
+		SELECT boot_val
 		FROM pg_catalog.pg_settings
 		WHERE name OPERATOR(pg_catalog.=) 'search_path';
@@ -134,7 +143,6 @@ BEGIN
 		RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
 	END IF;
 	IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
 		var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
 	ELSE
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index 2acfd9c41..eb9da2d02 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -25,18 +25,50 @@ DECLARE
 	var_result text;
 	var_cur_search_path text;
 BEGIN
-	SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
-	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
-		var_result := a_schema_name || ' already in database search_path';
+	WITH settings AS (
+		SELECT pg_catalog.unnest(setconfig) config
+		FROM pg_catalog.pg_db_role_setting
+		WHERE setdatabase OPERATOR(pg_catalog.=) (
+			SELECT oid
+			FROM pg_catalog.pg_database
+			WHERE datname OPERATOR(pg_catalog.=) pg_catalog.current_database()
+		) and setrole OPERATOR(pg_catalog.=) 0
+	SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
+	FROM settings WHERE config like 'search_path=%'
+	INTO var_cur_search_path;
+	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
+		SELECT setting
+	END IF;
+		SELECT boot_val
+		FROM pg_catalog.pg_settings
+		WHERE name OPERATOR(pg_catalog.=) 'search_path';
+		RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
+	END IF;
+	IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
 	ELSE
-		var_cur_search_path := var_cur_search_path || ', '
-                        || pg_catalog.quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
-                              || ' SET search_path = ' || var_cur_search_path;
-		var_result := a_schema_name || ' has been added to end of database search_path ';
+		var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
+                       OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
+		EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
+                             OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
 	END IF;
-	EXECUTE 'SET search_path = ' || var_cur_search_path;
+	EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
   RETURN var_result;
 END
Summary of changes:
 NEWS                                    |  4 ++-
 doc/introduction.xml                    |  1 +
 extensions/postgis_extension_helper.sql | 12 ++++++--
 topology/sql/manage/ManageHelper.sql.in | 50 +++++++++++++++++++++++++++------
 4 files changed, 55 insertions(+), 12 deletions(-)
hooks/post-receive
