[postgis-tickets] [PostGIS] #5469: make install fails on extensions
PostGIS trac at osgeo.org
Mon Aug 7 18:22:31 PDT 2023
  Reporter:  tbussmann              |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 @pramsey are you having same issue on your MacOSX setup?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5469#comment:2>
