[postgis-tickets] [PostGIS] #5469: make install fails on extensions
PostGIS trac at osgeo.org
Tue Aug 8 02:55:13 PDT 2023
  Reporter:  tbussmann              |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 The attached patch seems harmless to me. We could actually also start
 using that variable rather than the hard-coded `mkdir -p` we currently
 use, but I'd not go there for now (if it ain't broke ...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5469#comment:3>
