[postgis-tickets] [PostGIS] #5469: make install fails on extensions
PostGIS trac at osgeo.org
Tue Aug 8 02:55:42 PDT 2023
  Reporter:  tbussmann              |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"60f5ae20dd6d8790b58ac19cde9f04639b573358/git" 60f5ae2/git]:
 {{{#!CommitTicketReference repository="git"
 revision="60f5ae20dd6d8790b58ac19cde9f04639b573358"
 Make MKDIR_P variable available in extension Makefiles
 Closes #5469
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5469#comment:4>
