[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-25-gf4348feb4
Sun Aug 13 22:45:17 PDT 2023
the project "PostGIS".
       via  f4348feb455a61fb47b577df9c7868971cd70e45 (commit)
       via  2c34b8e25274993814d33aaf396162346331f7c4 (commit)
       via  3487e44baf6e1f8ea3f1c61cba2b67217ccfa98d (commit)
      from  406a13467120f9a44d66b4a8ec6763f9b609dbde (commit)
revisions in full, below.
commit f4348feb455a61fb47b577df9c7868971cd70e45
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 14 01:43:44 2023 -0400
    Fix mingw64 install
    References #5469
    References #5476
    for PostGIS 3.5.0dev
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 31fca2d2f..dc13a272a 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -205,7 +205,9 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL = @PERL@
-MKDIR_P = @MKDIR_P@
+ifneq (@MKDIR_P@,)
+	MKDIR_P = @MKDIR_P@
+endif
 srcdir = @srcdir@
 top_srcdir = @top_srcdir@
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 4723145c9..09ccc8c08 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -149,7 +149,10 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL = @PERL@
+ifneq (@MKDIR_P@,)
+endif
 VPATH = @srcdir@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 2842aad38..ceb0eade2 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -131,7 +131,9 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL = @PERL@
+ifneq (@MKDIR_P@,)
+endif
 VPATH = @srcdir@
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index 7fea079f5..28f00a99c 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -103,7 +103,9 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL = @PERL@
+ifneq (@MKDIR_P@,)
+endif
 VPATH = @srcdir@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 3c18ee7b6..49c8a975a 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -214,7 +214,9 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL=@PERL@
+ifneq (@MKDIR_P@,)
+endif
 VPATH = @srcdir@
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 75ba45c85..f5c9c9920 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -108,7 +108,9 @@ PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 PERL=@PERL@
+ifneq (@MKDIR_P@,)
+endif
 VPATH = @srcdir@
commit 2c34b8e25274993814d33aaf396162346331f7c4
Date:   Sun Aug 13 23:26:07 2023 -0400
    PostGIS 3.4.0 notes
diff --git a/doc/po/de/release_notes.xml.po b/doc/po/de/release_notes.xml.po
index 607c6aaa1..1d80dfa0e 100644
--- a/doc/po/de/release_notes.xml.po
+++ b/doc/po/de/release_notes.xml.po
@@ -7,7 +7,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-08-12 03:32+0000\n"
+"POT-Creation-Date: 2023-08-14 03:15+0000\n"
 "PO-Revision-Date: 2022-01-10 13:38+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: German (http://www.transifex.com/postgis/postgis/language/"
@@ -39,7 +39,7 @@ msgstr ""
 #. Tag: para
 #: release_notes.xml:7
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -77,14 +77,37 @@ msgstr ""
 msgid "Vincent Bre (French Team)"
 msgstr ""
-#. Tag: title
+#. Tag: para
+#: release_notes.xml:16
+#, no-c-format
+msgid "There are 2 new ./configure switches:"
+msgstr ""
+#. Tag: para
 #: release_notes.xml:17
 #, no-c-format
+msgid ""
+"--disable-extension-upgrades-install, will skip installing all the extension "
+"upgrade scripts except for the ANY--currentversion. If you use this, you can "
+"install select upgrades using the postgis commandline tool"
+msgstr ""
+#. Tag: para
+#: release_notes.xml:18
+#, no-c-format
+msgid ""
+"--without-pgconfig, will build just the commandline tools raster2pgsql and "
+"shp2pgsql even if PostgreSQL is not installed"
+msgstr ""
+#. Tag: title
+#: release_notes.xml:22
+#, no-c-format
 msgid "New features"
 msgstr ""
 #. Tag: para
-#: release_notes.xml:18
+#: release_notes.xml:23
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5055\">5055</ulink>, "
@@ -92,7 +115,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:19
+#: release_notes.xml:24
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5052\">5052</ulink>, "
@@ -100,7 +123,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:21
+#: release_notes.xml:26
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5306\">5306</ulink>, "
@@ -108,14 +131,14 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:22
+#: release_notes.xml:27
 #, no-c-format
 msgid ""
 "New install-extension-upgrades command in postgis script (Sandro Santilli)"
 msgstr ""
 #. Tag: para
-#: release_notes.xml:23
+#: release_notes.xml:28
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5257\">5257</ulink>, "
@@ -125,7 +148,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:24
+#: release_notes.xml:29
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5006\">5006</ulink>, "
@@ -134,7 +157,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:25
+#: release_notes.xml:30
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5283\">5283</ulink>, "
@@ -142,7 +165,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:26
+#: release_notes.xml:31
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5286\">5286</ulink>, "
@@ -150,7 +173,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:27
+#: release_notes.xml:32
 #, no-c-format
 msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/703\">703</ulink>, "
@@ -158,7 +181,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:28
+#: release_notes.xml:33
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5336\">5336</ulink>, "
@@ -166,7 +189,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:29
+#: release_notes.xml:34
 #, no-c-format
 msgid ""
 "Allow singleton geometry to be inserted into Geometry(Multi*) columns (Paul "
@@ -174,7 +197,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:30
+#: release_notes.xml:35
 #, no-c-format
 msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/721\">721</ulink>, New "
@@ -182,7 +205,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:31
+#: release_notes.xml:36
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5397\">5397</ulink>, "
@@ -190,7 +213,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:32
+#: release_notes.xml:37
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5373\">5373</"
@@ -199,7 +222,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:33
+#: release_notes.xml:38
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5267\">5267</ulink>, "
@@ -207,7 +230,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:34
+#: release_notes.xml:39
 #, no-c-format
 msgid ""
@@ -215,7 +238,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:35
+#: release_notes.xml:40
 #, no-c-format
 msgid ""
 "New coverage functions ST_CoverageInvalidEdges, ST_CoverageSimplify, "
@@ -223,13 +246,13 @@ msgid ""
 msgstr ""
 #. Tag: title
-#: release_notes.xml:39
+#: release_notes.xml:44
 #, no-c-format
 msgid "Enhancements"
 msgstr ""
 #. Tag: para
-#: release_notes.xml:40
+#: release_notes.xml:45
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5194\">5194</ulink>, do "
@@ -237,7 +260,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:41
+#: release_notes.xml:46
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5092\">5092</ulink>, "
@@ -245,7 +268,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:42
+#: release_notes.xml:47
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/635\">635</ulink>, honour "
@@ -253,7 +276,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:43
+#: release_notes.xml:48
 #, no-c-format
 msgid ""
 "Honour --mandir (and --prefix) configure switch for man pages install path "
@@ -261,7 +284,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:44
+#: release_notes.xml:49
 #, no-c-format
 msgid ""
 "Honour --htmldir (and --docdir and --prefix) configure switch for html pages "
@@ -269,7 +292,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:46
+#: release_notes.xml:51
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5447\">5447</ulink> "
@@ -278,7 +301,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:48
+#: release_notes.xml:53
 #, no-c-format
 msgid ""
 "[postgis_topology] Speed up check of topology faces without edges (Sandro "
@@ -286,7 +309,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:49
+#: release_notes.xml:54
 #, no-c-format
 msgid ""
 "[postgis_topology] Speed up coincident nodes check in topology validation "
@@ -294,7 +317,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:50
+#: release_notes.xml:55
 #, no-c-format
 msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/718\">718</ulink>, "
@@ -302,7 +325,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:51
+#: release_notes.xml:56
 #, no-c-format
 msgid ""
 "Repair spatial planner stats to use computed selectivity for contains/within "
@@ -310,7 +333,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:52
+#: release_notes.xml:57
 #, no-c-format
 msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/734\">734</ulink>, "
@@ -319,7 +342,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:53
+#: release_notes.xml:58
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5177\">5177</ulink>, "
@@ -328,14 +351,14 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:55
+#: release_notes.xml:60
 #, no-c-format
 msgid ""
 "ST_Project signature for geometry, and two-point signature (Paul Ramsey)"
 msgstr ""
 #. Tag: para
-#: release_notes.xml:56
+#: release_notes.xml:61
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/4913\">4913</ulink>, "
@@ -344,7 +367,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:58
+#: release_notes.xml:63
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5266\">5266</ulink>, "
@@ -353,13 +376,13 @@ msgid ""
 msgstr ""
 #. Tag: title
-#: release_notes.xml:62
+#: release_notes.xml:67
 #, no-c-format
 msgid "Breaking Changes"
 msgstr ""
 #. Tag: para
-#: release_notes.xml:63
+#: release_notes.xml:68
 #, no-c-format
 msgid ""
 "<ulink url=\"https://trac.osgeo.org/postgis/ticket/5229\">5229</ulink>, Drop "
@@ -367,7 +390,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:64
+#: release_notes.xml:69
 #, no-c-format
 msgid ""
@@ -379,7 +402,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:68
+#: release_notes.xml:73
 #, no-c-format
 msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/5447\">5447</ulink>, "
@@ -387,7 +410,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: release_notes.xml:70
+#: release_notes.xml:75
 #, no-c-format
 msgid ""
 "Utilities now installed in OS bin or user specified --bindir and --prefix "
diff --git a/doc/po/es/release_notes.xml.po b/doc/po/es/release_notes.xml.po
index 1508e2d8c..7a9a8fd71 100644
--- a/doc/po/es/release_notes.xml.po
+++ b/doc/po/es/release_notes.xml.po
 msgstr ""
 "PO-Revision-Date: 2021-11-28 22:22+0000\n"
 "Last-Translator: Regina Obe\n"
 "Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/"
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/fr/release_notes.xml.po b/doc/po/fr/release_notes.xml.po
index 2ab0475e6..dfdc80705 100644
--- a/doc/po/fr/release_notes.xml.po
+++ b/doc/po/fr/release_notes.xml.po
@@ -10,7 +10,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-07-03 18:19+0000\n"
 "Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
@@ -43,7 +43,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -81,14 +81,37 @@ msgstr ""
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -96,7 +119,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -104,7 +127,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -112,14 +135,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -129,7 +152,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -138,7 +161,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -146,7 +169,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -154,7 +177,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -162,7 +185,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -170,7 +193,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -178,7 +201,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -186,7 +209,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -194,7 +217,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -203,7 +226,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -211,7 +234,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -219,7 +242,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -227,13 +250,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -241,7 +264,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -249,7 +272,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -257,7 +280,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -265,7 +288,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -273,7 +296,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -282,7 +305,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -290,7 +313,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -298,7 +321,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -306,7 +329,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -314,7 +337,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -323,7 +346,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -332,14 +355,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -348,7 +371,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -357,13 +380,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -371,7 +394,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -383,7 +406,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -391,7 +414,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/it_IT/release_notes.xml.po b/doc/po/it_IT/release_notes.xml.po
index f56519780..4cef4ada7 100644
--- a/doc/po/it_IT/release_notes.xml.po
+++ b/doc/po/it_IT/release_notes.xml.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Language-Team: Italian (Italy) (http://www.transifex.com/postgis/postgis/"
@@ -37,7 +37,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -75,14 +75,37 @@ msgstr ""
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -90,7 +113,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -98,7 +121,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -106,14 +129,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -123,7 +146,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -132,7 +155,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -140,7 +163,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -148,7 +171,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -156,7 +179,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -164,7 +187,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -172,7 +195,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -180,7 +203,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -188,7 +211,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -197,7 +220,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -205,7 +228,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -213,7 +236,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -221,13 +244,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -235,7 +258,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -243,7 +266,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -251,7 +274,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -259,7 +282,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -267,7 +290,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -276,7 +299,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -284,7 +307,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -292,7 +315,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -300,7 +323,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -308,7 +331,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -317,7 +340,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -326,14 +349,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -342,7 +365,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -351,13 +374,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -365,7 +388,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -377,7 +400,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -385,7 +408,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/ja/release_notes.xml.po b/doc/po/ja/release_notes.xml.po
index 9bb165449..085ce6357 100644
--- a/doc/po/ja/release_notes.xml.po
+++ b/doc/po/ja/release_notes.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-08-07 10:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
@@ -40,7 +40,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -83,14 +83,37 @@ msgstr "Teramoto Ikuhiroさん (日本語チーム)"
 msgstr "Vincent Breさん (フランス語チーム)"
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr "新機能"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -100,7 +123,7 @@ msgstr ""
 "なマニュアル国際化 (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -110,7 +133,7 @@ msgstr ""
 "postgis_extensions_upgradeでの対象バージョンへの対応 (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -120,7 +143,7 @@ msgstr ""
 "パイル時のGEOSバージョンの表示 (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -129,7 +152,7 @@ msgstr ""
 "さん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -143,7 +166,7 @@ msgstr ""
 "PostgreSQL 16への対応のための変更 (Regina Obeさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -155,7 +178,7 @@ msgstr ""
 "ST_Transform: PROJパイプライン対応 (Robert Coupさん, Koordinates)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -165,7 +188,7 @@ msgstr ""
 "[postgis_topology] RenameTopology (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -175,7 +198,7 @@ msgstr ""
 "[postgis_topology] RenameTopoGeometryColumn (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -186,7 +209,7 @@ msgstr ""
 "ん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -197,7 +220,7 @@ msgstr ""
 "さん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -207,7 +230,7 @@ msgstr ""
 "Ramseyさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -218,7 +241,7 @@ msgstr ""
 "ん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -228,7 +251,7 @@ msgstr ""
 "[address_standardizer] debug_standardize_address関数 (Regina Obeさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -240,7 +263,7 @@ msgstr ""
 "必要です (Martin Davisさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -251,7 +274,7 @@ msgstr ""
 "Ramseyさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -261,7 +284,7 @@ msgstr ""
 "ンストリングを拡張するST_LineExtend (Paul Ramseyさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -271,13 +294,13 @@ msgstr ""
 "ST_CoverageUnion (Paul Ramseyさん)"
 #. Tag: title
 #, no-c-format
 msgstr "性能強化"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -288,7 +311,7 @@ msgstr ""
 "Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -299,7 +322,7 @@ msgstr ""
 "Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -310,7 +333,7 @@ msgstr ""
 "になりました (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -320,7 +343,7 @@ msgstr ""
 "(と --prefix)を見るようになりました (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -330,7 +353,7 @@ msgstr ""
 "docdir と --prefix)を見るようになりました (Sandro Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -339,7 +362,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -349,7 +372,7 @@ msgstr ""
 "Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -359,7 +382,7 @@ msgstr ""
 "Santilliさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -369,7 +392,7 @@ msgstr ""
 "ST_QuantizeCoordinates(): 実装の速度向上 (Even Rouaultさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -379,7 +402,7 @@ msgstr ""
 "使用するようにしました (Paul Ramseyさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -391,7 +414,7 @@ msgstr ""
 "ん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -400,7 +423,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -409,7 +432,7 @@ msgstr ""
 "Ramseyさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -421,7 +444,7 @@ msgstr ""
 "対応するようになりました (Regina Obeさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -434,13 +457,13 @@ msgstr ""
 "Ramseyさん)"
 #. Tag: title
 #, no-c-format
 msgstr "大幅な変更"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -450,7 +473,7 @@ msgstr ""
 "6.1未満およびPostgreSQL 11へのサポートの終了 (Regina Obeさん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -468,7 +491,7 @@ msgstr ""
 "ん)"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -476,7 +499,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/ko_KR/release_notes.xml.po b/doc/po/ko_KR/release_notes.xml.po
index f6a06cc3b..27cb47392 100644
--- a/doc/po/ko_KR/release_notes.xml.po
+++ b/doc/po/ko_KR/release_notes.xml.po
 msgstr ""
 "Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/"
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/pl/release_notes.xml.po b/doc/po/pl/release_notes.xml.po
index 76988e05a..2961c917b 100644
--- a/doc/po/pl/release_notes.xml.po
+++ b/doc/po/pl/release_notes.xml.po
 msgstr ""
 "Language-Team: Polish (http://www.transifex.com/postgis/postgis/language/"
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/pt_BR/release_notes.xml.po b/doc/po/pt_BR/release_notes.xml.po
index 07a2b55e5..68de7e55c 100644
--- a/doc/po/pt_BR/release_notes.xml.po
+++ b/doc/po/pt_BR/release_notes.xml.po
@@ -9,7 +9,7 @@ msgid ""
 msgstr ""
 "Language-Team: Portuguese (Brazil) (http://www.transifex.com/postgis/postgis/"
@@ -41,7 +41,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -79,14 +79,37 @@ msgstr ""
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -94,7 +117,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -102,7 +125,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -110,14 +133,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -127,7 +150,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -136,7 +159,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -144,7 +167,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -152,7 +175,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -160,7 +183,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -168,7 +191,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -176,7 +199,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -184,7 +207,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -192,7 +215,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -201,7 +224,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -209,7 +232,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -217,7 +240,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -225,13 +248,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -239,7 +262,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -247,7 +270,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -255,7 +278,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -263,7 +286,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -271,7 +294,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -280,7 +303,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -288,7 +311,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -296,7 +319,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -304,7 +327,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -312,7 +335,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -321,7 +344,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -330,14 +353,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -346,7 +369,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -355,13 +378,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -369,7 +392,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -381,7 +404,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -389,7 +412,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/ru/release_notes.xml.po b/doc/po/ru/release_notes.xml.po
index 1d2a43367..af553aa77 100644
--- a/doc/po/ru/release_notes.xml.po
+++ b/doc/po/ru/release_notes.xml.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Language-Team: Russian (Russia) (http://www.transifex.com/postgis/postgis/"
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -78,14 +78,37 @@ msgstr ""
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -93,7 +116,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -101,7 +124,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -109,14 +132,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -126,7 +149,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -135,7 +158,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -143,7 +166,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -151,7 +174,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -159,7 +182,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -167,7 +190,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -175,7 +198,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -183,7 +206,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -191,7 +214,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -200,7 +223,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -208,7 +231,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -216,7 +239,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -224,13 +247,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -238,7 +261,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -246,7 +269,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -254,7 +277,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -262,7 +285,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -270,7 +293,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -279,7 +302,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -287,7 +310,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -295,7 +318,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -303,7 +326,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -311,7 +334,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -320,7 +343,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -329,14 +352,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -345,7 +368,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -354,13 +377,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -368,7 +391,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -380,7 +403,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -388,7 +411,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/templates/release_notes.xml.pot b/doc/po/templates/release_notes.xml.pot
index 1c35db6fe..4e2144bd3 100644
--- a/doc/po/templates/release_notes.xml.pot
+++ b/doc/po/templates/release_notes.xml.pot
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -35,7 +35,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2023/08/13"
+msgid "2023/08/15"
 msgstr ""
 #. Tag: para
@@ -73,14 +73,37 @@ msgstr ""
 msgstr ""
-#. Tag: title
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: title
+#, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -88,7 +111,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -104,14 +127,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -121,7 +144,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -130,7 +153,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -195,7 +218,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -219,13 +242,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -233,7 +256,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -274,7 +297,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -315,7 +338,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -324,14 +347,14 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -340,7 +363,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -349,13 +372,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -363,7 +386,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -375,7 +398,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
commit 3487e44baf6e1f8ea3f1c61cba2b67217ccfa98d
Date:   Sun Aug 13 23:07:45 2023 -0400
    Put in news the two new configure switches
     - --disable-extension-upgrades-install
     - --without-pgconfig
diff --git a/NEWS b/NEWS
index 270fb28c1..acfaa8e53 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,11 @@ Many thanks to our translation teams, in particular:
 Teramoto Ikuhiro (Japanese Team)
+There are 2 new ./configure switches:
+ -  --disable-extension-upgrades-install, will skip installing all the extension upgrade scripts except for the ANY--currentversion. If you use this, you can install select upgrades using the postgis commandline tool
+ -  --without-pgconfig, will build just the commandline tools
+    raster2pgsql and shp2pgsql even if PostgreSQL is not installed
 * New Features *
   - #5055, complete manual internationalization (Sandro Santilli)
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 897382c26..9f804e5d3 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
     <subtitle>Release Notes</subtitle>
         <sect1>
             <title>PostGIS 3.4.0</title>
-            <para>2023/08/13</para>
+            <para>2023/08/15</para>
             <para>This version requires PostgreSQL 12 or higher, GEOS 3.6 or higher, and Proj 6.1+.
             To take advantage of all features, GEOS 3.12+ is needed.
             To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.</para>
@@ -13,6 +13,11 @@
             <para>Teramoto Ikuhiro (Japanese Team)</para>
             <para>Vincent Bre (French Team)</para>
+            <para>There are 2 new ./configure switches:</para>
+            <itemizedlist><listitem><para>--disable-extension-upgrades-install, will skip installing all the extension upgrade scripts except for the ANY--currentversion.  If you use this, you can install select upgrades using the postgis commandline tool</para></listitem>
+                <listitem><para>--without-pgconfig, will build just the commandline tools raster2pgsql and shp2pgsql even if PostgreSQL is not installed</para></listitem>
+            </itemizedlist>
             <simplesect>
                 <title>New features</title>
                 <para><ulink url="https://trac.osgeo.org/postgis/ticket/5055">5055</ulink>, complete manual internationalization (Sandro Santilli)</para>
Summary of changes:
 NEWS                                          |   5 ++
 doc/po/de/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/es/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/fr/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/it_IT/release_notes.xml.po             | 105 ++++++++++++++++----------
 doc/po/ja/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/ko_KR/release_notes.xml.po             | 105 ++++++++++++++++----------
 doc/po/pl/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/pt_BR/release_notes.xml.po             | 105 ++++++++++++++++----------
 doc/po/ru/release_notes.xml.po                | 105 ++++++++++++++++----------
 doc/po/templates/release_notes.xml.pot        | 105 ++++++++++++++++----------
 doc/release_notes.xml                         |   7 +-
 extensions/address_standardizer/Makefile.in   |   4 +-
 extensions/postgis/Makefile.in                |   5 +-
 extensions/postgis_raster/Makefile.in         |   4 +-
 extensions/postgis_sfcgal/Makefile.in         |   4 +-
 extensions/postgis_tiger_geocoder/Makefile.in |   4 +-
 extensions/postgis_topology/Makefile.in       |   4 +-
 18 files changed, 670 insertions(+), 417 deletions(-)
hooks/post-receive
