[postgis-tickets] [PostGIS] #5477: distclean target fails (No rule to make target 'local-clean'.)
PostGIS trac at osgeo.org
Sun Aug 13 23:56:06 PDT 2023
 Reporter:  Bas Couwenberg         |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 `make distclean` fails:
 rule=distclean; \
 for lang in it_IT pt_BR fr es pl ko_KR de ja ru; do \
     echo "Making $rule for language $lang..."; \
     /usr/bin/make -C po/$lang local-$rule || exit 1; \
   done
 Making distclean for language it_IT...
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/it_IT'
 rm -f Makefile
 rm -rf /build/postgis-3.4.0~rc3+dfsg/doc/html/postgis-web-mobile-en/
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/it_IT'
 Making distclean for language pt_BR...
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/pt_BR'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/pt_BR'
 Making distclean for language fr...
 rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/fr'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/fr'
 Making distclean for language es...
 rm -f list_3d_functions.xsl.xml list_aggregates.xsl.xml
 list_box_functions.xsl.xml list_curved_geometry_functions.xsl.xml
 list_dump_functions.xsl.xml list_geography_functions.xsl.xml
 list_new_functions.xsl.xml list_raster_functions.xsl.
 xml list_sqlmm_functions.xsl.xml list_window_functions.xsl.xml
 table_body_function_support_matrix.xsl.xml postgis-out.xml
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/es'
 rm -f Makefile
 rm -f postgis-nospecial.xml
 rm -f address_standardizer_required.tag curve_support.tag
 geography_transform.tag index_aware.tag M_support.tag P_support.tag
 sfcgal_enhanced.tag sfcgal_required.tag sfs_compliant.tag
 sqlmm_compliant.tag T_support.tag Z_support.tag
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/es'
 Making distclean for language pl...
 /usr/bin/make -C /build/postgis-3.4.0~rc3+dfsg/doc/html/images clean
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/pl'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/pl'
 Making distclean for language ko_KR...
 '/build/postgis-3.4.0~rc3+dfsg/doc/html/images'
 rm -f styles.o generator.o
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ko_KR'
 rm -f Makefile
 rm -f generator
 rm -rf generator-temp-*
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ko_KR'
 Making distclean for language de...
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/html/images'
 rm -f postgis_gardentest_34.sql
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/de'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/de'
 rm -f raster_gardentest_34.sql
 Making distclean for language ja...
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ja'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ja'
 Making distclean for language ru...
 rm -f *.tmp
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ru'
 rm -f Makefile
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/ru'
 /usr/bin/make clean-localized
 make[4]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc'
 rule=clean; \
   done
 Making clean for language it_IT...
 make[5]: Entering directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/it_IT'
 make[5]: *** No rule to make target 'local-clean'.  Stop.
 make[5]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc/po/it_IT'
 make[4]: *** [Makefile:355: clean-localized] Error 1
 make[4]: Leaving directory '/build/postgis-3.4.0~rc3+dfsg/doc'
 I think the problem is that `distclean` has removed the `Makefile` which
 provides the `local-clean` target.
 The order should be the other way around, first `clean` then `distclean`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5477>
