[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-34-g5e41ce9fd
git at osgeo.org
git at osgeo.org
Fri Aug 18 20:08:47 PDT 2023
the project "PostGIS".
via 5e41ce9fd4da7ff13f5836ccf16c04a247c00866 (commit)
via b88a59098cfa0e23c57f542ff34825d30065a7f7 (commit)
from 7905ec144ecee9896238a58c0883bd3e4c7a2854 (commit)
revisions in full, below.
commit 5e41ce9fd4da7ff13f5836ccf16c04a247c00866
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Fri Aug 18 02:40:31 2023 +0000
Translated using Weblate (Japanese)
Currently translated at 100.0% (223 of 223 strings)
Translation: postgis/introduction.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/ja/
diff --git a/doc/po/ja/introduction.xml.po b/doc/po/ja/introduction.xml.po
index 4434a6f24..e5af0c322 100644
--- a/doc/po/ja/introduction.xml.po
+++ b/doc/po/ja/introduction.xml.po
@@ -8,7 +8,7 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2023-08-12 00:40+0000\n"
-"PO-Revision-Date: 2023-08-01 03:08+0000\n"
+"PO-Revision-Date: 2023-08-19 03:08+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"introductionxml/ja/>\n"
@@ -774,7 +774,7 @@ msgstr "Jeff Adams"
#: introduction.xml:269
#, no-c-format
msgid "Jelte Fennema"
-msgstr ""
+msgstr "Jelte Fennema"
#. Tag: member
#: introduction.xml:270
commit b88a59098cfa0e23c57f542ff34825d30065a7f7
Date: Fri Aug 18 03:04:28 2023 +0000
Currently translated at 100.0% (51 of 51 strings)
Translation: postgis/release_notes.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/release_notesxml/ja/
diff --git a/doc/po/ja/release_notes.xml.po b/doc/po/ja/release_notes.xml.po
index 085ce6357..c91a6610f 100644
--- a/doc/po/ja/release_notes.xml.po
+++ b/doc/po/ja/release_notes.xml.po
"POT-Creation-Date: 2023-08-14 03:15+0000\n"
-"PO-Revision-Date: 2023-08-07 10:08+0000\n"
"release_notesxml/ja/>\n"
@@ -35,13 +35,13 @@ msgstr "リリースノート"
#: release_notes.xml:6
#, no-c-format
msgid "PostGIS 3.4.0"
-msgstr ""
+msgstr "PostGIS 3.4.0"
#. Tag: para
#: release_notes.xml:7
#, no-c-format
msgid "2023/08/15"
-msgstr ""
+msgstr "2023/08/15"
#. Tag: para
#: release_notes.xml:8
@@ -87,7 +87,7 @@ msgstr "Vincent Breさん (フランス語チーム)"
#: release_notes.xml:16
#, no-c-format
msgid "There are 2 new ./configure switches:"
-msgstr ""
+msgstr "2個の./configureスイッチが新設されました:"
#. Tag: para
#: release_notes.xml:17
@@ -97,6 +97,10 @@ msgid ""
"upgrade scripts except for the ANY--currentversion. If you use this, you can "
"install select upgrades using the postgis commandline tool"
msgstr ""
+"--disable-extension-upgrades-install, ANY--currentversionを除く全てのエクステ"
+"ンションのアップグレードスクリプトのインストールを行いません。これを使用する"
+"と、PostGISコマンドラインツールを使って選択したアップグレードのインストールが"
+"可能になります"
#. Tag: para
#: release_notes.xml:18
@@ -105,6 +109,8 @@ msgid ""
"--without-pgconfig, will build just the commandline tools raster2pgsql and "
"shp2pgsql even if PostgreSQL is not installed"
msgstr ""
+"--without-pgconfig, PostgreSQLがインストールされていなくてもコマンドラインツ"
+"ールのraster2pgsqlとshp2pgsqlとのビルドを行います"
#. Tag: title
#: release_notes.xml:22
@@ -360,6 +366,9 @@ msgid ""
"Manual pages added for postgis and postgis_restore utilities (Sandro "
"Santilli)"
msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5447\">5447</ulink> "
+"postgisとpostgis_restoreの両ユーティリティのマニュアルページを追加 (Sandro "
+"Santilliさん)"
#. Tag: para
#: release_notes.xml:53
@@ -421,6 +430,9 @@ msgid ""
"Allow building tools without PostgreSQL server headers. Respect prefix/bin "
"for tools install (Sandro Santilli)"
msgstr ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5177\">5177</ulink>, Postg"
+"reSQLサーバヘッダが無くてもビルドできるようにしました。ツールのインストール先"
+"について、prefix/binを尊重するようになりました (Sandro Santilliさん)"
#. Tag: para
#: release_notes.xml:60
@@ -497,6 +509,8 @@ msgid ""
"<ulink url=\"https://github.com/postgis/postgis/pull/5447\">5447</ulink>, "
"postgis_restore.pl renamed to postgis_restore (Sandro Santilli)"
msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/5447\">5447</ulink>, "
+"postgis_restore.plをpostgis_restoreに名前変更 (Sandro Santilliさん)"
#. Tag: para
#: release_notes.xml:75
@@ -507,3 +521,8 @@ msgid ""
"postgis_restore, shp2pgsql, raster2pgsql, pgsql2shp, pgtopo_import, "
"pgtopo_export)"
msgstr ""
+"ユーティリティ (postgis, postgis_restore, shp2pgsql, raster2pgsql, "
+"pgsql2shp, pgtopo_import, pgtopo_export)は、Windowsを除いて、PostgreSQLのbin"
+"ディレクトリやエクステンションのインストールディレクトリでなく、OSのbinディレ"
+"クトリまたは--bindirや--"
+"prefixで指定されたディレクトリにインストールされるようになりました"
Summary of changes:
doc/po/ja/introduction.xml.po | 4 ++--
doc/po/ja/release_notes.xml.po | 27 +++++++++++++++++++++++----
2 files changed, 25 insertions(+), 6 deletions(-)
hooks/post-receive
