[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-53-gc4f91fd
Sat Aug 19 18:30:16 PDT 2023
the project "postgis.net".
The branch, website has been updated
       via  c4f91fd83bdea79f0abfe1c018a06f176ec3b31e (commit)
      from  d7d4d2ccea5c726252cc35d88551c556ba72257b (commit)
revisions in full, below.
commit c4f91fd83bdea79f0abfe1c018a06f176ec3b31e
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Aug 19 21:30:10 2023 -0400
    Update news about Windows PostGIS Bundle 3.4.0 release
diff --git a/content/documentation/getting_started/install_windows/released_versions.md b/content/documentation/getting_started/install_windows/released_versions.md
index 54cece4..8cd730f 100644
--- a/content/documentation/getting_started/install_windows/released_versions.md
+++ b/content/documentation/getting_started/install_windows/released_versions.md
@@ -1,38 +1,35 @@
 title: Latest Released Version
-date: 2023-06-01
+date: 2023-08-19
 weight: 10
 geekdocHidden: true
 geekdocHiddenTocTree: false
-PostGIS 3.3.3 came out May 30th, 2023. Windows PostGIS Bundle 3.3.3 was released June 2nd, 2023.
+PostGIS 3.4.0 came out August 15th, 2023. Windows PostGIS Bundle 3.4.0 was released August 19th, 2023.
-The release includes an additional extension called [MobilityDb](https://mobilitydb.com/) (the develop 1.1 version for PostgreSQL 12-15).
-PostgreSQL 11 version does not include mobilitydb because it is not supported in MobilityDb 1.1.
+Binaries for versions of PostgreSQL 12-16 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 12-6(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
-Binaries for versions of PostgreSQL 11-15 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 11-15(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
+If you are using PostgreSQL < 12, use the PostGIS 3.3 bundle, because PostGIS 3.4+  does not support those versions.
-If you are using PostgreSQL < 11, use the PostGIS 3.2.3 bundle, because PostGIS 3.3+  does not support those versions.
+PostGIS 3.4.0 bundle includes:
-PostGIS 3.3.3 bundle includes:
-  * PostGIS 3.3.3 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2023-03-16-geos-3-11-2-released/) 3.11.2, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (1.4.1), address_standardizer, topology
+  * PostGIS 3.4.0 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2023-06-27-geos-3-12-released/) 3.12.02, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (1.4.1), address_standardizer, topology
   * PostGIS Tiger geocoder extension - Tiger 2022
   * pgRouting 3.5 [pgRouting 3.5.0](https://docs.pgrouting.org/3.5/en/index.html)
   * Commandline raster loader (raster2pgsql), shapefile import/export (shp2pgsql,pgsql2shp)
   * Commandline [osm2pgrouting 2.3.8](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3) for loading data from .osm files into pgRouting routable format
   * GUI: shp2pgsql-gui which has both import and export support for geometry/geography
-  * [ogrfdw 1.1.3](https://github.com/pramsey/pgsql-ogr-fdw/releases/tag/v1.1.3)  - spatial foreign data wrapper for
+  * [ogrfdw 1.1.4](https://github.com/pramsey/pgsql-ogr-fdw/releases/tag/v1.1.4)  - spatial foreign data wrapper for
 		reading both spatial (spatial columns become postgis geometry) and non-spatial data.    [IMPORT FOREIGN SCHEMA](http://www.postgresonline.com/journal/archives/359-Import-Foreign-Schema-for-ogr_fdw-for-PostgreSQL-9.5.html) support
     New features in 1.1 - `character_encoding` option and utility functions `ogr_fdw_drivers()`, `ogr_fdw_version()`
-  * [GDAL 3.6.4](https://gdal.org/download.html#current-releases) with OpenJPEG 2.4.0 (JPEG 2000), ODBC, Curl, SQLite3 (for GeoPackage and OSM support), excel (XLS) (via FreeXL 1.0.6), libreoffice, XLSX spreadsheet (via expat)  (used by both PostGIS raster and ogrfdw)
+  * [GDAL 3.7.1](https://gdal.org/download.html#current-releases) with OpenJPEG 2.4.0 (JPEG 2000), ODBC, Curl, SQLite3 (for GeoPackage and OSM support), excel (XLS) (via FreeXL 1.0.6), libreoffice, XLSX spreadsheet (via expat), Arrow 13.0 for Arrow, Parquet, and GeoParquet support  (used by both PostGIS raster and ogrfdw)
   * [pgpointcloud](https://github.com/pgpointcloud/pointcloud) 1.2.4
     for querying LIDAR point cloud and in/out functions to convert to PostGIS geometry
-  * [h3-pg](https://github.com/zachasme/h3-pg) 4.0.3
-    for using Uber h3 api and converting h3 index representations to postgis geometry/geography.
-  * [MobilityDB](https://mobilitydb.com) [develop branch 1.1 66849fed01](https://github.com/MobilityDB/MobilityDB/tree/66849fed01)
+  * [h3-pg](https://github.com/zachasme/h3-pg) 4.1.3
+    for using Uber h3 api and converting h3 index representations to postgis geometry/geography/raster (raster support is new in this release).
+  * [MobilityDB](https://mobilitydb.com) [v1.1.0alpha](https://github.com/MobilityDB/MobilityDB/releases/tag/v1.1.0-alpha)
     for managing trajectories.  Includes many temporal spatial types and functions for them. Refer to [Enabling PostGIS Extensions: MobilityDb](../enabling_postgis/#mobilitydb) for guidance.
 The simplest way to get PostGIS on Windows for the EnterpriseDb Windows PostgreSQL distribution is using the StackBuilder.
Summary of changes:
 .../install_windows/released_versions.md           | 25 ++++++++++------------
 1 file changed, 11 insertions(+), 14 deletions(-)
hooks/post-receive
postgis.net
