[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
trac at osgeo.org
Mon Aug 28 02:31:44 PDT 2023
#5484: ERROR: cannot drop function st_value(raster,geometry,boolean) because
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.1
Component: build/upgrade/install | Version: 3.4.x
Resolution: | Keywords:
Comment (by strk):
The ST_Value function has undertaken a few revisions but was never given
the `Replaces` comment, and also lacks other availability/changed
comments.
We currently define:
st_value(rast raster, band integer, x integer, y integer,
exclude_nodata_value boolean DEFAULT TRUE)
-- Changed: 3.2.0 added resample arg
st_value(rast raster, band integer, pt geometry, exclude_nodata_value
boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
st_value(rast raster, x integer, y integer, exclude_nodata_value boolean
DEFAULT TRUE)
st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT
TRUE)
Chances are a Replaces comment going with the `Changed` line would
suffice, but unfortunately I've troubles building both 3.1 and 3.4 with
the same proj version to test upgrades myself.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:3>
