[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 02:39:56 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by strk):
 Actually, comparing the ST_Value signatures in 3.1 and 3.4 branches I fail
 to see why the version taking {{{ (raster,geometry,boolean) }}} should be
 drop, as we have exactly the same signature in both 3.1.1 and 3.4.0:
    st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT
 TRUE) RETURNS float8
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:4>
