[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 02:50:13 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by strk):
 We have `DROP FUNCTION IF EXISTS st_value(raster, geometry, boolean);
 ` in rtpostgis_upgrade_cleanup.sql.in which is going to happen *before*
 re-creating that function. There's no trace as WHY this pre-upgrade is
 done. Maybe argument names were changed, but no comment says when.
 This cleanup step is also found in 3.1.1 so the rename of arguments must
 be older than 3.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:5>
