[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 08:21:19 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.1.10
 Component:  build/upgrade/install  |    Version:  2.1.x
Resolution:                         |   Keywords:
Comment (by strk):
 The fix is somewhat dangerous but the automated tests for upgrades from
 older versions seem to be ok, so I'm not sure whether or not to backport
 the fix. What is your opinion on the matter Regina ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:10>
