[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 11:46:10 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.1.10
 Component:  build/upgrade/install  |    Version:  2.1.x
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"fe22c117751e1de0968ed444ac10df5028f82ecc/git"
 fe22c117/git]:
 {{{#!CommitTicketReference repository="git"
 revision="fe22c117751e1de0968ed444ac10df5028f82ecc"
 Fix upgrade with view using st_value(raster,geometry,bool)
 Adds support for argument names in Replaces sql comments.
 Includes regression test.
 References #5484 in 3.4 branch (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:11>
