[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
trac at osgeo.org
Mon Aug 28 10:12:22 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: build/upgrade/install | Version:
Resolution: | Keywords:
Comment (by strk):
Documentation does not say when signature changed:
https://postgis.net/docs/en/RT_ST_Clip.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:2>
