[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 10:16:18 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:
Resolution:                         |   Keywords:
Comment (by strk):
 All the signatures in current master branch for ST_Clip seem to match the
 signatures in stable-3.0 so these drops must also be coming from 2.x times
 or earlier
 Support for Replaces comment entered the codebase with 3.1
 ([3d947448b9c939b321bc22b85c719845722ecc3d/git]) so we can try fixing this
 bug with a Replaces coment, although it wasn't specifically written for
 parameters renames.
 Support for parameters renames entered the codebase in 3.5.0dev and
 backport is not necessarely happening, see
 https://trac.osgeo.org/postgis/ticket/5484#comment:9
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:3>
