[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 10:23:25 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:
Resolution:                         |   Keywords:
Comment (by strk):
 Same signatures in stable-2.3 as well
 The signatures, from 2.3 to current master are:
 -- 1
 st_clip(
   rast raster,
   nband integer[],
   geom geometry,
   nodataval double precision[] DEFAULT NULL,
   crop boolean DEFAULT TRUE
 ) RETURNS raster
 -- 2
 st_clip(
   rast raster, nband integer,
   geom geometry,
   nodataval double precision, crop boolean DEFAULT TRUE
 ) RETURNS raster
 -- 3
 st_clip(
   rast raster,
   nband integer,
   geom geometry,
   crop boolean
 ) RETURNS raster
 -- 4
 st_clip(
   rast raster,
   geom geometry,
 ) RETURNS raster
 -- 5
 st_clip(
   rast raster,
   geom geometry,
 ) RETURNS raster
 -- 6
 st_clip(
   rast raster,
   geom geometry,
   crop boolean
 ) RETURNS raster
 It would be about time to consolidate more, now that we support
 Replaces...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:4>
