[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 11:23:13 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:
Resolution:                         |   Keywords:
Comment (by strk):
 PostGIS 2.0.0 is the first PostGIS version having raster support
 integrated.
 Differences in st_clip signatures from stable-2.0 to stable-2.1 are:
  - signature 1 had the "band" parameter renamed to "nband"
  - signature 3 had the "band" parameter renamed to "nband"
  - a different signature was removed: st_clip(raster, int, geometry,
 float8[], boolean);
 All other signatures were the same from 2.0.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:5>
