[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 11:50:56 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:
Resolution:                         |   Keywords:
Comment (by strk):
 Ok bug confirmed by https://woodie.osgeo.org/repos/30/pipeline/860/9
 Next I'll see if the fix is also confirmed
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:6>
