[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-62-ge1b7db454
Mon Aug 28 13:04:43 PDT 2023
the project "PostGIS".
       via  e1b7db45486fea9cb3c0be8d58cbd2a785b631f4 (commit)
      from  ce07fb3430cf32ef575c30d7aa55c7e2b3156de2 (commit)
revisions in full, below.
commit e1b7db45486fea9cb3c0be8d58cbd2a785b631f4
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 28 19:10:20 2023 +0200
    Fix upgrades in presence of views using ST_Clip
    Includes regress test
    References #5488 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index dad551aa3..5424398fb 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -6555,11 +6555,14 @@ CREATE OR REPLACE FUNCTION _st_clip(
 	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
 -- Availability: 2.0.0
--- Changed: 2.1.0
+-- Changed: 2.1.0 - renamed the band parameter
+-- Replaces st_clip(rast raster, band int, geom geometry, nodataval float8, crop boolean) deprecated in 2.1.0
 CREATE OR REPLACE FUNCTION st_clip(
-	rast raster, nband integer[],
+	rast raster,
+	nband integer[],
 	geom geometry,
-	nodataval double precision[] DEFAULT NULL, crop boolean DEFAULT TRUE
+	nodataval double precision[] DEFAULT NULL,
+	crop boolean DEFAULT TRUE
 	RETURNS raster
  	AS $$
@@ -6584,8 +6587,11 @@ CREATE OR REPLACE FUNCTION st_clip(
 	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
+-- Changed: 2.1.0 -- renamed the band parameter
+-- Replaces st_clip(rast raster, band int, geom geometry, crop boolean) deprecated in 2.1.0
-	rast raster, nband integer,
+	rast raster,
+	nband integer,
 	geom geometry,
 	crop boolean
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index cde5bdddf..5f4a8f9aa 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -69,6 +69,8 @@ DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, text);
 DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, int4, text);
 -- Removed in 2.1.0
 DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, text, text, text, float8, text, text, text, float8);
+-- Removed in 2.1.0
+DROP FUNCTION IF EXISTS st_clip(raster, int, geometry, float8[], boolean);
 -- Removed in 2.2.0
 DROP FUNCTION IF EXISTS _st_mapalgebra(rastbandarg[],regprocedure,text,integer,integer,text,raster,text[]);
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 95f2e2e6c..bed083b66 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -452,12 +452,9 @@ DROP FUNCTION IF EXISTS st_intersection(raster, int, geometry, text, regprocedur
 DROP FUNCTION IF EXISTS st_intersection(raster, int, geometry, regprocedure);
 DROP FUNCTION IF EXISTS st_intersection(raster, geometry, text, regprocedure);
 DROP FUNCTION IF EXISTS st_intersection(raster, geometry, regprocedure);
-DROP FUNCTION IF EXISTS st_clip(raster, integer, geometry, boolean);
-DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8, boolean);
-DROP FUNCTION IF EXISTS st_clip(raster, geometry, boolean);
-DROP FUNCTION IF EXISTS st_clip(raster, int, geometry, float8, boolean);
-DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8[], boolean);
-DROP FUNCTION IF EXISTS st_clip(raster, integer, geometry, float8[], boolean);
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8, boolean); --------- sig5, not changed since 2.0.0, maybe changed before ?
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, boolean); ----------------- sig6, not changed since 2.0.0, maybe changed before ?
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8[], boolean); ------- sig4, not changed since 2.0.0, maybe changed before ?
 -- refactoring of functions
 DROP FUNCTION IF EXISTS _st_dumpaswktpolygons(raster, integer);
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index fffb6f7f0..b044120f7 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -1,6 +1,10 @@
 DROP VIEW upgrade_test_raster_view_st_value;
+DROP VIEW upgrade_test_raster_view_st_clip;
 DROP TABLE upgrade_test_raster;
 DROP TABLE upgrade_test_raster_with_regular_blocking;
 -- Drop functions deprecated on upgrade
 DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
+--DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index c2e42c97f..c445200c8 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -38,3 +38,17 @@ CREATE VIEW upgrade_test_raster_view_st_value AS
 SELECT
 	ST_Value(r, ST_MakePoint(0, 0))
 FROM upgrade_test_raster;
+-- See https://trac.osgeo.org/postgis/ticket/5488
+-- st_clip(raster,integer,geometry,double precision,boolean)
+CREATE VIEW upgrade_test_raster_view_st_clip AS
+SELECT
+	-- signature dropped in PostGIS-2.1.0
+	--st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::float8[], NULL::boolean),
+	-- sig1 new in PostGIS-2.1.0
+	--st_clip(NULL::raster, NULL::int[], NULL::geometry, NULL::float8[], NULL::boolean),
+	st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::float8, NULL::boolean) sig2,
+	st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::boolean) sig3,
+	st_clip(NULL::raster, NULL::geometry, NULL::float8[], NULL::boolean) sig4,
+	st_clip(NULL::raster, NULL::geometry, NULL::float8, NULL::boolean) sig5,
+	st_clip(NULL::raster, NULL::geometry, NULL::boolean) sig6;
Summary of changes:
 raster/rt_pg/rtpostgis.sql.in                            | 14 ++++++++++----
 raster/rt_pg/rtpostgis_drop.sql.in                       |  2 ++
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in            |  9 +++------
 raster/test/regress/hooks/hook-after-upgrade-raster.sql  |  4 ++++
 raster/test/regress/hooks/hook-before-upgrade-raster.sql | 14 ++++++++++++++
 5 files changed, 33 insertions(+), 10 deletions(-)
hooks/post-receive
