[postgis-tickets] [SCM] PostGIS branch stable-3.4 updated. 3.4.0-4-gfe22c1177
git at osgeo.org
git at osgeo.org
Mon Aug 28 11:45:46 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
via fe22c117751e1de0968ed444ac10df5028f82ecc (commit)
from 0adf05207b4b1fe13178a90a0f16fe5a473278f8 (commit)
revisions in full, below.
commit fe22c117751e1de0968ed444ac10df5028f82ecc
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Aug 28 11:20:31 2023 +0200
Fix upgrade with view using st_value(raster,geometry,bool)
Adds support for argument names in Replaces sql comments.
Includes regression test.
References #5484 in 3.4 branch (3.4.1dev)
diff --git a/NEWS b/NEWS
index dce553251..2d9d4e459 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
* Bug Fixes *
+ - #5484, Fix upgrade with view using st_value(raster,geometry,bool)
- #5479, postgis_full_version() and postgis_gdal_version() sometimes
warn of deprecated SRID: 2163 (Regina Obe)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index ef0aa82ef..dad551aa3 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -5,7 +5,7 @@
-- http://trac.osgeo.org/postgis/wiki/WKTRaster
-- Copyright (c) 2015-2017 Regina Obe <lr at pcorp.us>
--- Copyright (c) 2009-2012 Sandro Santilli <strk at kbt.io>
+-- Copyright (c) 2009-2023 Sandro Santilli <strk at kbt.io>
-- Copyright (c) 2009-2010 Pierre Racine <pierre.racine at sbf.ulaval.ca>
-- Copyright (c) 2009-2010 Jorge Arevalo <jorge.arevalo at deimos-space.com>
-- Copyright (c) 2009-2010 Mateusz Loskot <mateusz at loskot.net>
@@ -4622,6 +4622,10 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_n
AS $$ SELECT st_value($1, 1::integer, $2, $3, $4) $$
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
+-- Availability: 2.0.0
+-- Changed: 2.1.0 - renamed the boolean parameter name
+-- Replaces st_value(raster, geometry) deprecated in 2.0.0 (signature existed in WKTRaster)
+-- Replaces st_value(rast raster, pt geometry, hasnodata boolean) deprecated in 2.1.0
CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
RETURNS float8
AS $$ SELECT @extschema at .ST_value($1, 1::integer, $2, $3, 'nearest'::text) $$
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index cbcae6bcd..95f2e2e6c 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -7,6 +7,7 @@
-- Copyright (c) 2011 Regina Obe <lr at pcorp.us>
-- Copyright (C) 2011 Regents of the University of California
-- <bkpark at ucdavis.edu>
+-- Copyright (c) 2013-2023 Sandro Santilli <strk at kbt.io>
-- This program is free software; you can redistribute it and/or
-- modify it under the terms of the GNU General Public License
@@ -250,12 +251,10 @@ DROP FUNCTION IF EXISTS st_bandpixeltype(raster, integer);
DROP FUNCTION IF EXISTS st_value(raster, integer, integer, integer);
DROP FUNCTION IF EXISTS st_value(raster, integer, integer);
DROP FUNCTION IF EXISTS st_value(raster, integer, geometry);
-DROP FUNCTION IF EXISTS st_value(raster, geometry);
-- signature changed
DROP FUNCTION IF EXISTS st_value(raster, integer, integer, integer, boolean);
DROP FUNCTION IF EXISTS st_value(raster, integer, integer, boolean);
DROP FUNCTION IF EXISTS st_value(raster, integer, geometry, boolean);
-DROP FUNCTION IF EXISTS st_value(raster, geometry, boolean);
DROP FUNCTION IF EXISTS st_value(raster, integer, geometry, double precision);
DROP FUNCTION IF EXISTS st_value(raster, geometry, double precision);
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index b220246ea..fffb6f7f0 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -1,2 +1,6 @@
+DROP VIEW upgrade_test_raster_view_st_value;
DROP TABLE upgrade_test_raster;
DROP TABLE upgrade_test_raster_with_regular_blocking;
+-- Drop functions deprecated on upgrade
+DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 94d972fc3..c2e42c97f 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -31,3 +31,10 @@ INSERT INTO upgrade_test_raster_with_regular_blocking(r) VALUES
--SET client_min_messages TO ERROR;
SELECT AddRasterConstraints('upgrade_test_raster_with_regular_blocking', 'r', 'regular_blocking');
+-- See https://trac.osgeo.org/postgis/ticket/5484
+CREATE VIEW upgrade_test_raster_view_st_value AS
+SELECT
+ ST_Value(r, ST_MakePoint(0, 0))
+FROM upgrade_test_raster;
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index afc6f00b0..eeaf4ed43 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -4,7 +4,7 @@
# PostGIS - Spatial Types for PostgreSQL
# http://postgis.net
-# Copyright (C) 2014-2021 Sandro Santilli <strk at kbt.io>
+# Copyright (C) 2014-2023 Sandro Santilli <strk at kbt.io>
# Copyright (C) 2009-2010 Paul Ramsey <pramsey at opengeo.org>
# Copyright (C) 2005 Refractions Research Inc.
@@ -202,16 +202,79 @@ while(<INPUT>)
my ($name, $args, $ver) = @$replaced;
$name = lc($name); # lowercase the name
+ # Check if there are argument names
+ my @argtypearray;
+ my @argnamearray;
+ my $numnamedargs = 0;
+ foreach my $a ( split ',', $args )
+ my $argtype = $a;
+ # NOTE: we should not consider OUT parameters
+ #print "-- ARG: [$argtype]\n";
+ if ( $argtype =~ / *([^ ]+) *([^ ]+)/ ) {
+ my $argname = $1;
+ $argtype = $2;
+ #print "-- ARGNAME: [$argname]\n";
+ #print "-- ARGTYPE: [$argtype]\n";
+ push @argnamearray, "'$argname'";
+ $numnamedargs++;
+ push @argtypearray, "$argtype";
+ my $argnames = join ',', @argnamearray;
+ my $argtypes = join ',', @argtypearray;
my $renamed = $name . '_deprecated_by_postgis_' . ${ver};
my $replacement = "${renamed}(${args})";
push @renamed_deprecated_functions, ${renamed};
print <<"EOF";
--- Rename $name ( $args ) deprecated in PostGIS $ver
+-- Rename $name ( $args ) deprecated in PostGIS $ver, if needed
DO LANGUAGE 'plpgsql'
\$postgis_proc_upgrade\$
DECLARE
detail TEXT;
+ argnames TEXT[];
BEGIN
+ -- Check if the deprecated function exists
+ BEGIN
+ SELECT proargnames
+ FROM pg_catalog.pg_proc
+ WHERE oid = '$name($argtypes)'::regprocedure
+ INTO argnames;
+EOF
+ # Check for argument names match, if any argument name
+ # was given in the Replaces comment
+ if ( $numnamedargs )
+ print <<"EOF";
+ -- Check if the deprecated function has the expected $numnamedargs argument names
+ IF argnames[1:$numnamedargs] != ARRAY[$argnames]::text[]
+ THEN
+ RAISE DEBUG
+ 'Function $name($argtypes) exist but has argnames % (not %)',
+ argnames, ARRAY[$argnames];
+ RETURN; -- nothing to do
+ END IF;
+EOF
+ print <<"EOF";
+ EXCEPTION
+ WHEN undefined_function THEN
+ RAISE DEBUG 'Replaced function $name($argtypes) does not exist';
+ WHEN OTHERS THEN
+ GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
+ RAISE EXCEPTION 'Checking if replaced function $name($args) exists got % (%)', SQLERRM, SQLSTATE
+ USING DETAIL = detail;
+ END;
-- Rename the replaced function, to avoid ambiguities.
-- The renamed function will eventually be drop.
BEGIN
Summary of changes:
NEWS | 1 +
raster/rt_pg/rtpostgis.sql.in | 6 +-
raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 3 +-
.../regress/hooks/hook-after-upgrade-raster.sql | 4 ++
.../regress/hooks/hook-before-upgrade-raster.sql | 7 +++
utils/create_upgrade.pl | 67 +++++++++++++++++++++-
6 files changed, 83 insertions(+), 5 deletions(-)
hooks/post-receive
