[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 13:17:33 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  2.0.x
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * version:   => 2.0.x
 * resolution:   => fixed
 * milestone:   => PostGIS 3.4.1
Comment:
 I'm ok with the backport to 3.4, earlier versions will still have trouble
 upgrading raster in presence of view. Feel free to reopen if you want a
 backport.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:10>
