[postgis-tickets] [PostGIS] #5489: Upgrade from 3.1.1: ERROR: cannot drop function st_intersects(raster, geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 13:37:34 PDT 2023
st_intersects(raster,geometry,integer) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by strk):
 Current signatures (3.5.0dev, same as 2.0.0):
  -- 1. st_intersects(rast1 raster, nband1 integer, rast2 raster, nband2
 integer)
  -- 2. st_intersects(rast1 raster, rast2 raster)
  -- 3. st_intersects(geom geometry, rast raster, nband integer DEFAULT
 NULL)
  -- 4. st_intersects(rast raster, geom geometry, nband integer DEFAULT
 NULL)
  -- 5. st_intersects(rast raster, nband integer, geom geometry)
 A lot of ST_Intersects signatures are dropped in 2.0.0, which doesn't make
 much sense as 2.0 was the first version including raster.
 I think I'm going to stop dropping them all and call it a day.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5489#comment:1>
