[postgis-tickets] [PostGIS] #5489: Upgrade from 3.1.1: ERROR: cannot drop function st_intersects(raster, geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 13:56:27 PDT 2023
st_intersects(raster,geometry,integer) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by strk):
 The other 2 internal signatures which did not change from 2.0.0 to
 3.5.0dev are:
  1. _st_intersects(geom geometry, rast raster, nband integer DEFAULT NULL)
  2. _st_intersects(rast1 raster, nband1 integer, rast2 raster, nband2
 integer)
 Additionally stable-2.0 (dropped in stable-2.1) had:
  3. _st_intersects(rast raster, geom geometry, nband integer DEFAULT NULL)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5489#comment:2>
