[postgis-tickets] [PostGIS] #5490: Upgrade from 3.1.1: ERROR: cannot drop function st_slope(raster, integer, text, text, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 14:25:50 PDT 2023
st_slope(raster,integer,text,text,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  raster
Comment (by strk):
 Current signatures (2.1.0 to 3.5.0dev aka master):
 -- 1
 st_slope(
  rast raster,
  nband integer,
  customextent raster,
  pixeltype text DEFAULT '32BF',
  units text DEFAULT 'DEGREES',
  scale double precision DEFAULT 1.0,
  interpolate_nodata boolean DEFAULT FALSE
 -- 2
 st_slope(
  rast raster,
  nband integer DEFAULT 1,
 In stable-2.0 we have a single signature:
   st_slope(rast raster, band integer, pixeltype text)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5490#comment:1>
